Ongoing 2019 Tri Glide Build-Out w/ lots of photos, videos and observations
Huge Thanks!!
I should have asked this before doing the Oil Filter Relocation install. Thought I was helping to further lower the temperature by keeping the lines more in the wind.:blush:
Couple of weeks ago I had a real pucker situation.....speeding along 60 mph in heavy rural traffic saw an obstacle in the roadway, looked like a curved aluminum access panel. No time to avoid it, so just hit it dead center with front tire. Front wheel bounced over It and then it made the most god awful noise going under the trike and out the rear. Pulled over as quickly as possible and checked underneath for damage, especially to those hoses...thankfully none, and luckily it didn't rip the catch can off or damage it.
So I'll be relocating those hoses as you described when I do the Oil Cooler install.:)
Wow! Glad that metal did not come up and hit YOU! That could hurt/cut pretty good!
Oil Pressure
I may be wrong but I think there is another benefit to the relocation kit and that is I have seen a 3 PSI increase in idle oil pressure at 90+ degrees ambient temp. 11 PSI before, 14 PSI now.
Kurt
Kurt
That is probably a function of the oil being cooler, thus more viscous, which is great!
Possibly you hear a little less top end rattle due to the oil not thinning out as much.
Hey Alan!
The lights in the dash are LED and are going on and off at a speed that the camera catches. Not sure what hz they are. Camera is set at 30 fps.
On 103 Wetheads relocating the oil filter, result in the oil temps being 8-10 degrees cooler. When we add the Oil Cooler set-up to the Oil Filter relocation, the oil temperatures are consistently 30-34 degrees cooler. So, it is not as much as the M8, but still significant.
Harley has done a better job at keeping the heat off the rider and passenger on the M8's than they did the TC's. But the M8's actually run hotter, contrary to what is felt by most riders.
Thanks! Yes, many Town Squares in Mississippi are dying, but even though a Walmart moved into Holly Springs (on the outskirts) the town has done a good job of keeping the Town Square thriving.
My riders backrest that I have on my 2019 TG has seen well over 200,000 miles on previous bikes and trikes...the padding is worn out. Going to be looking at it and see if I can replace the padding in it, or if it is finally time to get a new backrest.
This is either the 3rd or 4th bike it has been on. :xzqxz:
Ask Grasshopper, maybe they will help.
I was curious Kevin, have you had your tranny migration issue fixed yet?
Yeah, the Grasshopper backrests are nice. I have one on my Softail. Showed my lumpy backrest to Mary the other day, I think she is going to pull the cover and put some new comfort foam in there....if that does not work out, I probably will go with a Grasshopper.
Regarding transmission transfer to the primary, I have NOT done the vent yet. The last month has been quite a series of unanticipated events. We are still working at getting back to "normal".
I have decided I will be installing the vent myself. Need to order it (it's $50) and then take the time to put it in. Probably will get it done in November.
I could get it done under warranty...but it will cost less in time and hassle just to pay the $50 and do it myself. We'll probably make a video of the process.
Hoping you guys will be at the shop in 10 days or so Kevin. Wanting to bring a buddy from Savanna TN to see the mods on your 19 TG, especially the oil relocation and cooler.
I look forward to the video. I think that's a great idea, due to it being a hot topic.
Yeah, gonna order the vent today. Prolly install it next week.
Yes, we will be there. Really looking forward to your visit.
Tried to buy a Primary Vent Kit today.* Called 3 dealerships, none of them would sell me one.* They are calling it a recall only product.* Even if a bike is out of warranty, if it transfers (per their testing) then it gets a Primary Vent Kit installed at no cost.
I would rather do it myself than go thru all the back and forth with them testing it.
Anyone know a dealership that will sell one?
I'm sure there aren't any dealers out there that would sell you the primary vent, just guessing since you called 3 dealerships and they said no. I have heard it takes around 2 hours to do, just drive the trike there or haul it and have the dealer do it then bring it home, I don't think they keep it to do testing at least haven't heard of that at all. Maybe ISP-FL can chime in since he had his done at a dealer and waited for it.
All for now Trampas
https://www.surdyke.com/PartsMain.a...SubCatID=388&CatID=&Name=&CatName=Maintenance
All for now Trampas
I had mine done at Four Rivers Harley in Paducah Kevin, which is a ways from you so that probably won't help you much. My buddy from TN has a really good relationship with them and he got me in right away while I was down there with him on a ride recently.
They actually had ordered the kit for his 2018 but used it on mine instead. The week after I left they had re-ordered and got another one in to do his. It does take around 2 hours.
All for now Trampas
All three of our local dealers want me to come in multiple times to accomplish the following steps-
1. They drain trans and primary, fill and seal
2. I then ride for x number of miles
3. I ride back and they check how much has transferred
4. If x amount has transferred then it qualifies for warranty installation of the vent and they set an appointment for me to go back a THIRD time
5. I go back the third time and they install the vent
This process would eat 14-16 hours of my time, going back and forth, and that's if everything went smoothly. I'd rather just pay $50 for it, and then an hour or two of my time and know that it was done right.
  • Like
Reactions: MDO
vent kit
Kevin they sell the kit here at worthnorth harley just talked to them but so does syrdke. I had mine installed at st joe. I didn't have to jump through hoops to get it done. They also replaced the bcm to see if it would stop throughing thoes codes, it still does.
Just curious but I typed in the part number and description and got quite a few hits at various HD's with surdyke being the cheapest and it looks like you can buy it, guess a person won't know until he hits add it the cart.
Another question I read in another forum that the vent kit goes on the outside but I was told at my harley dealer it goes inside the primary because he seen me looking 2 and 3 wheelers on the floor, was looking for the vent and that is when he told me it is on the inside, don't know but in the future I guess I will know if mine transfers trannie fluid to the primary.
Ok for the ones that have had the vent thing done, what was the mileage on your trike when you noticed it transferring????
All for now Trampas
James, I had around 8,000 miles on mine when I discovered my tranny was low. I put another 800 or 900 miles on it after taking some out of primary plus toping off tranny. Tranny was probably only down another ounce or two.
All for now Trampas
Yeah, I had an old part number, that is why I was not finding it.
I now have mine ordered from Surdyke, hopefully I'll receive it next week sometime.
Part of the vent is inside the primary and part of it is outside the primary. It requires drilling a hole.
Mine has been transferring since the first time I checked, at around 500 miles. I now have a bit over 5k miles and it has been transferring more and more (per mile) as time goes by.
The first 1000 miles it only transferred a couple of ounces. The last 1000 miles it transferred 5-6 ounces.
HD has had a real hard time trying to fix this issue. They have been thru a bunch of different attempts. It is still not 100% sure that the vent will fix it in every instance. I have a friend who is a HD mechanic that says he has seen a couple of bikes that still transferred After the vent was installed.
I'm not sure what % are affected....no where near 50%, probably not even 20%. I was hoping that I would not be one of them...but, I'm hoping the vent makes the issue a distant memory. :)
If not, lots of guys have had good luck with modifying their clutch rod. Hope I don't need to do that.
As far as the hoop jumping, that is obviously our local dealerships not knowing what's what, since I am able to buy the kit elsewhere.
Desertgecko
