Ongoing 2014 Tri-Glide build-out, lots of pics and thoughts on the differences
Re: Ongoing 2014 Tri-Glide build-out, lots of pics and thoughts on the differences
Nuttin like getting them fixed under warranty. Best way!
Yep!
Just heard from them today, they have a bunch of parts on order-
New front brake Master Cylinder
New Left side turn signal control switch (I thought it might be the BCM, but they say it is the switch)
They have not determined if it needs a new panhard rod, or if the existing one just needs to be adjusted & tightened up. (the jam nut on one side was loose from the factory)
New horn bracket
They have the clutch recall kit in stock
New front linkage shift arm- it won't tighten up all the way (and no, I'm not a "stomper")
They already have the hardware for front engine stabilizer
Seems like a lot of issues for a new machine?
I have some custom handlebars that the dealer installed for me. They messed up the switch and Master Cylinder in the process.
Top stabilizer, panhard rod, linkage arm, & horn are all factory issues.
Clutch recall a factory issue also.
I have 10k miles on it...on my 11 TG by this mileage they were replacing the entire top end under warranty! So, by comparison, I'm doing better on this one. :)
I do tend to ride hard, so if something is borderline in design or quality, I'll probably be pushing it over to failure. Although I've never had an issue with a stabilizer, linkage arm or horn before.
The pic below is the '11, After the top end rebuild, and me doing things to cool it down. Never had another engine problem after that.
The TG's get treated well compared to the Sporty...as you can see in the vid below. It's never had any warranty work. Knock on wood!
I just got the TG back from the Dealership.
They replaced the horn bracket under warranty.
Did the clutch recall.
Installed new front master cyclinder
Replaced the left side switch...now all my lights work!
Did the front stabilizer with a new spacer. I noticed they did not use factory washers, but used lock washers.
They did not touch the panhard rod, the jam nut is still loose.
The shift linkage arm is still loose. They tried, but said next time I bring it in they will work on it again. Also, they forgot to touch up the frame where there is raw metal showing from the stabilizer bolt knocking around when it fell out.
Really happy to have all my lights again, and that they replaced the horn bracket under warranty.
Wow! Time flies.
Been riding and enjoying the TG since I got it back.
Just took it back in for them to fix the shift linkage arm, touch up the frame, and a couple of other things that did not get done last time it was in for warranty work.
I will be picking it back up on the 24th. By that time I should have my one-off "slip-ons" done with the high heat finish (black) and then will install them with some custom end caps.
Here's a pic of the end caps. Not 100% sure why, but I'm pretty excited about getting these on the TG. They're aluminum and still need to be polished.
why would they not take care of all the issues the first time the bike was in there? i hear of this kind of service more and more. when i bought my streeglide there was hardly any oil in the transmission.
:laugh::laugh::laugh:
When they did the clutch recall, they re-installed it wrong and it was leaking. Dunno why.
They did not fix the shift arm last time....they said they tried...dunno why they called and said it was ready when they knew they did not fix it.
They did not fix the paint...dunno why, it was right on the work order.
I already took care of the panhard rod jam nut that they did not do when it was in last.
They did replace the horn under warranty last time...which I wasn't sure if they would, so that was nice. But after I picked it up, I went to use it, it is defective, sounds like a sick duck. I rarely use the horn, & did not think to test it when I picked it up. Dunno why the "tech" who installed it did not test it.
So, I guess I did not answer your question....cause it makes no sense to me either why they didn't.
As I noted months ago in this thread, I have not been satisfied with how much the Oil Bud oil cooler actually cools down the oil. I have not taken the time to remove the Oil Bud and replace it with a Jagg oil cooler.
However, the other day I did a little experiment.
I took a funnel, cut it in half (and did a few little fitment cuts) and then attached the two halves to the frame, underneath the water pump cover. The theory was that they would scoop air and push it across the oil bud.
It is a jerry-rig for sure, but I was happy to see it lowered the oil temps a solid 10 degrees, so that is giving me a solid 25 degree total drop out of the Oil Bud. Not nearly as much as I expected, but better than a poke in the eye with a sharp stick.
I do not see this as a long term fix, and the funnel halves are the lowest point now, so they may possibly get ripped/knocked off at some point, but until I take the time to remove the Oil Bud and decide where to put a Jagg cooler, it is what I am going to be running.
Here's a pic-
It should be noted that on bikes with no water pump assembly and shroud, I have seen the Oil Bud deliver impressive drops in oil temps, as it should for the impressive price. However, my experience with the waterheads has been less than satisfactory, and it is understandable, the pump & shroud are blocking the flow of air over the unit, whereas with no pump and shroud the unit is directly in the wind.
I am glad we have got you and msocko3 and Fuzzy and some of the other guys who aren't afraid to take a wrench or a funnel to their bikes in order to make them better. Then you are so kind to share things with us including lots of pictures. I appreciate your posts and especially the trip photos. We might not get to Alaska this year but I have seen it vicariously through yours and Mary's eyes. Hey thanks for all you guys do
Steve
Steve
Cool! :)
Back earlier in this thread I mentioned how Mary did not like the stock backrest, especially on longer rides. I removed it for her, and she made a lower profile backrest, with no arms. She was Much more comfortable.
However, with the TP relocated back a ways, she decided she wanted some more padding going all the way down.
Here is what she had made prior to our Fall Colors Trip last year.
This picture shows her latest modification. She's ridden with it for about 1,000 miles now and says it's perfect. :)
On the exhaust front...I have ants in my pants to get my new end caps. The ones I pictured earlier....
....were not long enough. So some new ones are being made. I should have them in a day or so. Then I'll be able to get my slip-ons on with the new end caps. btw, ended up using rattle can ceramic coating (black) on them. So, the little bit of the pipe that is visible will be black, then have the Polished Aluminum end caps. :)
Cool!
I got 60 more miles in today. Took the long way home from the shop.
I'm looking forward to being done with the break-in miles. There is definitely more power there than the '11. Just can't tell how much with being easy on the wrist and RPM's.
Need to get the tank lift and Deluxe option installed...not used to that air coming over the top of the tank, makes for a bit of buffeting...plus I want that air going under the tank across the engine.
These were the first miles I put on it with the Wards Parts Werks fans installed.
After it was warmed up I let it sit for about 10 minutes idling, the radiator fans never kicked on...last ride (without the Wards fans) the radiator fans kicked on after about 5 minutes of idling.
My HD brand dipstick oil temp gauge went defective today...3 days after it was purchased.
:( So I had no way to see what the oil temps were doing.
From the pic below you can see I installed my backrest, air hawk and sheepskin. Definitely better for me...but need to get the handlebars made and installed...those puppies are just too short for me.
Also, hopefully you can't see in the pic that Mary put some 3M film on the fenders, the plastic between the fenders and the side covers, and also film on the side covers.
Here's a better pic of the Wards fans and the DK Custom Shift Linkage-
Here's a pic of the wheel after being rattle canned with clear. Looks good, hope it holds up. :)
Still have quite a few things to do on the list, but making progress.
Kevin,
Hard to to tell from the picture but did you lose quite a bit of the glossy shine to your wheels when you cleared them. I used the same paint and lost quite a bit of the original shine to the wheels. It also created a slightly rough texture as well. Looking at the picture you posted above it may have turned out the same. However; pictures can be misleading at times.
I just just ordered your tank lift kit, new shifter linkage and a few other things from DK today.
Handlebars
Hey Kevin,
Just curious about your handlebars, do you have a picture you could post of what you did?
Kind of thinking about the whole handlebar change thing right now. I've looked at a few different bars out there, the one I'm leaning towards has 5" pullback, much less than stock and less than some other taller bars as well. I know the pullback needs become less as you come up to shoulder height so maybe it will be okay. Looking for a real natural wrist position and still deciding between 12-14" bars.
So I was just curious what you ended up doing since you didn't like much of what was available when you were looking.
<Just curious about your handlebars, do you have a picture you could post of what you did?
Kind of thinking about the whole handlebar change thing right now. I've looked at a few different bars out there, the one I'm leaning towards has 5" pullback, much less than stock and less than some other taller bars as well. I know the pullback needs become less as you come up to shoulder height so maybe it will be okay. Looking for a real natural wrist position and still deciding between 12-14 bars.
I am on the road right now...don't have a picture. But it was really simple. I took some stock handlebars, cut them in the straight sections below the grips, welded in 8 or 9 of straight handlebar tube. Cleaned up the welds. Had them powder coated.
So they are the stock bars, with just a longer straight section on each side.
Remember to rotate the grips section to the natural wrist position before welding them onto the extension.
I would've never figured just exhaust tips would make that much of a difference.
Of course, I had the FullSac dx header put on, and it followed that they took the baffles out of my factory exhaust and put theirs in. They also changed out the tips of the exhaust as well.
I know that I have significantly more power than before. In fact, I've raised the front wheel off the ground (an inch or two--no wheelies here ;)) going into 2nd gear on several occasions. First time I wasn't expecting it AT ALL. I let out a big whoop when I realized what happened!
I know that I have significantly more power than before. In fact, I've raised the front wheel of the ground (an inch or two--no wheelies here ;)) going into 2nd gear on several occasions. First time I wasn't expecting it AT ALL. I let out a big whoop when I realized what happened!
Yeah, the large effect that the velocity and flow of exhaust gasses and energy pulses have on engine performance is one of the most mis-understood subjects in the HD world.
I contacted DKC and got a speedy reply from Dawn. As stated earlier these kits are not made by DK, they are made and packaged by VTwin Goodies. And it turns out that I got the correct hardware, but it was packaged with the wrong instructions. So Dawn sent me a copy of the correct instructions, and then it all made sense. This is a great example of EXCELLENT customer service
Below is a picture of the correct instruction sheet in case there might be others with the incorrect instructions, and a pic of the three bolts that are used to install this kit.
I found out the hard way that a 1/4 allen bit in a 1/4 Makita impact driver will not cut the mustard. I destroyed two 1/4 allen extensions and got the bit stuck inside the bolt that is captive in the rear part of the mount Luckily I was able to remove it with a few choice %#@ words, and tomorrow am borrowing a Snap-On 3/8 battery powered impact driver to get the job done right.
Another thing I meant to add to the update-
It's been almost a year and a half, and 24k miles. and the clear coat that I put on the rear wheels is holding up well. There are a few small spots where the clear has been chipped off, probably by riding on gravel roads, and there is only one small spot that is stained...that happened while at a HD dealership.
It certainly has been nice to spend 30 seconds a wheel to wipe them clean with pledge periodically.
Impact allen sockets are the best way when using impact guns to get the bolts out.. Or some heat as they most likey have Loctite on the bolts.
When installing the driver floorboard extensions,the rear bolt on the right side gave me a lot of trouble,probably because of thread locker. I finally had to run a tap through the hole to clean it up. Even after that,threading the new bolt back in was a snug fit.
Natural Choice Do it!
With the insight you have on the Tri-Glide Kevin you have to do it next. Harley could even take a look also. :wave4: ride safely fearless.
I have a question regarding the new front tire. My factory front tire on my 14 tri glide has 14000 on it and I think this winter I will replace it. Do you have the part number for your new front tire?
I am assuming it is the factory size that was originally on it just a rear tire. Part number would be a big help.
Thanks!
130/90B16 73H
The tread depth is 10/32, and I think the stock front tire had a tread depth of either 5 or 6/32
I am really liking how it feels and handles. Way too soon to know how many miles I'll get out of it, but I think it will probably be close to double what I would get out of a stock front tire.
wzejda
