Electric Fans on 2014 Tri Glide
ZZMACH1
5+ Posts
Apr 30, 2024
8
4
Contoocook, NH
Steve
Interested in knowing if the ECM map was changed by dynojet tuner from a stock map if it would effect the fans not turning on. I have
Replaced the Water Pump, and sensors and fans and they all work. Fuses are good. They just do not turn on when the bike is running or when
bike is in accessory mode and turning throttle cable and holding for 15 seconds. I do have Love Jugs on the bike to keep it cool and would like
the stock fans to work. Any suggestions?
Hey Steve, Welcome to Trike Talk…👍👍 And your first post…🫡
I would check to see if you have the correct map in the ECM. You may have a map for the oil cooled motor installed. That happened to me after installed the Power Vision tuner and I installed a twin cam map instead of the twin cooled map. Out for a ride and stopped at a red light and the next thing I felt my right foot getting hot and looked down and watched it puke out all of the coolant. An oil cooled motor Map will not turn on the water pump nor the fans. That little stunt got my warranty canceled two months after I purchased my Triglide.
Thanks for taking the time to respond to my inquiry. I will check to see map that is installed and make sure that it is in fact correct.
Thanks Again
Hi Steve, Welcome to Trike Talk
Stitch61
