Electric Fans on 2014 Tri Glide
ZZMACH1
5+ Posts
Apr 30, 2024
8
4
Contoocook, NH
Steve
I was suggested to check ECM Map or tune from the Dynojet to make sure that map was not for an oil cooled bike.
The map is correct for the Trike. Is there a way to test ECM to ensure that it is working properly to turn on the fans
when needed or the possbility of a short somewhere to prevent fans from working? Any Diagnostics to perform on the
ECM, Relays Possibly, the Bike is not throwing any Diagnostic Codes when checking with the Dynojet Black Box. Any suggestions
or direction as to how to diagnose this problem. The fans will not turn on from twisting the throttle when in accessory mode either.
Help!
Stitch61
