How does one go about greasing the rear u-joint on a 2003 Goldwing/Roadsmith trike. It appears unreachable to me. I can see it but not access it.
Update: Driveshaft had to be removed to access the rear yoke zerk on the u-joint.
On all applications I’ve seen you’ll need to rotate the drive shaft to “open” the angle of the u-joint to get to the grease fitting. Prevents drive shaft removal.
Tell that to Haus of Trikes Ft Myers Fl. RoadSmith dealers.
Can you not reach the zerk ball end with a needle grease adaptor like this
