Roadsmith Drive Shaft
Jan 19, 2013
1,347
192
Port Charlotte, FL
Butch
How does one go about greasing the rear u-joint on a 2003 Goldwing/Roadsmith trike. It appears unreachable to me. I can see it but not access it.
Update: Driveshaft had to be removed to access the rear yoke zerk on the u-joint.
I have two grease zirks on my D/Shaft, that I shoot a couple of shots of grease, twice a season.
I use a jack and just raise up the back of my trike and crawl under.....
2010 Honda Goldwing (Roadsmith model)
No need to remove any parts before greasing up
On all applications I’ve seen you’ll need to rotate the drive shaft to “open” the angle of the u-joint to get to the grease fitting. Prevents drive shaft removal.
Tell that to Haus of Trikes Ft Myers Fl. RoadSmith dealers.
Can you not reach the zerk ball end with a needle grease adaptor like this
Butch,
You should see two grease jirks on your shaft (I have them on my Roadsmith)
Jack up the rear of your trike, and rotate rear tires (slowly) you should see them, and give them a shot of grease (I do it twice a season)
PS: I hope your feeling better (I'd love to ride with you again, this season)
Butch,
Next time we meet, I'll crawl under your bike, and find these grease jurks for you OK?
Roger71!!
