Anyone using a 20w-60 engine oil during the summer to keep oil pressure up? Just curious if it works.
I use HD 20/50 Syndetic all year..... 10% to 100% When fully warmed up and at an idle oil pressure is at 5, at speed 32.... Cold at start 60... Where do you want it to be....:Shrug: [And why]
Mine runs about the same using M1 20w50 v-twin. Someone on one of the HD forums that lived in the desert southwest was using 20w-60 for the high summer temps. I was just curious if there was anyone in the HD Trike forum using 20w-60 oil and saw any benefits to using the heavier oil in trikes.
This post sound extremely logical. He may just be running in 100*+ temps though as he appears he lives in central Texas.It is actually more important to have oil at all the critical areas as fast as you can when starting the engine. The multi weight oil is supposed to give you that 20# performance at cold, but there isn't any reason to even think about the 60# portion of the oil unless you happen to be running way over 100*+ air temps all day everyday.
The 20w60 is mostly additives anyway & not 60# oil.
Watch your oil temp, & stay away from 300* temps that Harley says are normal.
