First of all, The brake didnt work when I bought the bike.
Second of all The Brake didn't work when I bought the bike.
Third of all you can run what you want and trust.... I dont trust the brake that HD puts on, I've heard to much bad about them. I'm not replacing pads all the time to find out that the stories I heard are true.... In 5300 miles the brake shouldn't be totally out of adjustment on the leaver... And the pads are only 1/32 worn off from new. So they may or may not have been replaced....
I'll use what I feel will work the best for me. And its not HDs setup, to me its already proven to me that its a poor design. They must agree too, since they changed to a different style of brake.
PS I'm a retired after 40 years, class 8 truck mechanic. So I do know just a little bit about brakes...
4th of all, you can use a rock as a chock if you want...:laugh:
PS We all just like to try to help others out a little if we can. We're a fairly friendly bunch. Not like those of them at the HD forum.
By the way, I'm Scott...nice to meet ya!
Sorry I pissed ya off :Shrug:. All I can say is mine works fine. Have a safe day .
New handlebars and grips
I installed my new handlebars and grips that I received as a Christmas gift (had carpel tunnel surgery on both wrists over winter and had to wait on them to heal before I tackled this). I put on Sweepers 2+2 and Kuryaken Iso grips. My trike is a 2017 and i had to get the wire extensions (69200034). The clutch and brake lines were really tight but I was able to get enough clearance for them to work. The hardest and most troublesome part was running the wiring inside of the handlebars. I finally had to do some Dremel work on the holes at the grip areas to get the wires control wire connectors to pass through. I know some folks have depinned the connectors but my eyesight would not allow me to do that.
So far, I like the change and I am able to sit in a more relaxed position and am even able to lean back some. As others have stated, turning does seem easier and for me especially the intersection starting out turns feel much easier.
I am not a mechanic but I can tinker about with things so, if you are debating changing out your bars, I believe it is doable for most folks. Watch the videos on YouTube and read what others have said in the forums and you can do it. I easily saved over $500.00 by doing my own.
My Bullet parking brake showed up today. Got it installed. It was easy as the video showed. It works great. Just pull the front brake on, doesn't take hardly any pressure, and push the button on the valve. Holds until you tap the brake and it comes right off.. Should work great at gas stops. Lots better than the make believe one HD has that always needs readjusted.
Today's Project #1
I've seen the pictures and read the comments on the Tour-Pak tethers breaking and breaking the TP or the lid when it falls open. The parachute cord is a good idea, but I didn't want to squish it under the nuts and risk it failing at some point, too. So I went one step farther and found these:
This one is mounted to the upper seat cushion bolt:IMG-0656.JPG
This one is mounted to the bottom tether anchor screw:
There is a fail point where the parachute cord passes through the angle plate, so I think I'm going to take it apart and put some shrink tubing on the cord where it passes through and try to beef it up. Should last a little longer that way.
Today's Project #3 Part 1
The reflectors on the rear fender didn't suit me, as they are just that, reflectors. I wanted a more "active" marker back there. Went to Custom Dynamics and ordered a pair of their Red TF-R Tru-Flex lighting strips with 20 LEDs. Then to Amazon for 25ft - 1/8 inch Flexo PET Expandable Braided Sleeving - Black/Red - Alex Tech Braided Cable Sleeve and GWHOLE 100Pcs 3M Adhesive Cable Clips. Then the fun began!
The "almost worthless" reflector.
Taking and marking measurements. Mark at center of reflector with a perpendicular line. Then measure the horizontal center of both ends of the reflector and write the measurements down for future reference.
Borrow the spouse's hair dryer (or use your own if you have one) and heat carefully, moving the dryer over the reflector until you can start to move it. Keep heating and work it around until you feel it loosen and peel it off. Clean the residue with your favorite cleaner and, you have a clean fender!
Painter's tape on the fender to cover the area where you will transfer your measurements for light bar placement. Mark your measurements and center the light bar on the lines. Make a mark where the wiring will pass through the fender. I put my wire marking to the rear of the bike. Use that mark to drill a 3/32" hole in the fender. OUCH! I know there are some that will cringe at doing this, but it's the only way!
You will want to thread the Light Bar wiring through the 1/8 inch Flexo PET Expandable Braided Sleeving - Black/Red - Alex Tech Braided Cable Sleeve at this point and shrink tube the end of it as close to the back of the Light Bar as you can. Again, Be careful with the heat on components. Then start your wiring through the (UGH!) hole in the fender. Tape it up out of the way to make work easier.
After bringing the wiring through the fender, I used the GWHOLE 100Pcs 3M Adhesive Cable Clips Cord Organizer Wire Management clips to secure the wiring to the inner fender back to the taillight and tapped into the black wire to connect the black wire and the blue wire to connect the red.
Results to follow. I've hit my picture limit in this post! TBC...
Today's Project #3 Part 2
This is the Custom Dynamics TF-R 20 LED mounted permanently in place with no power applied.
This is the Custom Dynamics TF-R 20 LED mounted permanently in place with power applied.
Makes a big difference! Picture was taken in a fully lighted garage.
I think I'm done with projects for today! And yes, I did torque the wheels when I put them back on, to 100 ft-lbs, and will recheck them after I go for a ride!
I wish I could help you...but we found it in a close out bin...for 50 cents....We frequent the place and I promise, if we see another one, I'll grab it for ya! jc
Mounted and wired DK Custom's Stealth LED Driving Lights. Replaced the OEM Seat Screw with Rivco's 2 1/2" Knurled Seat Knob. The longer knob is much needed with the one inch longer than stock Ultimate Seat. Did some quick cleaning with Purple Slice to remove bugs and lite grime from yesterday's run to Dealership for their April Lunch Ride. Maybe some installs tomorrow, but best of all.....some ride time!!
Rivco Seat Knob....no more fumbling with a screwdriver deep in that dark cavity.:)hd9000_updated_009_ps_web-1.jpg
Rivco Seat Knob....no more fumbling with a screwdriver deep in that dark cavity.:)View attachment 71003
Wes, I would keep an eye on that seat knob and make sure it stays tight. I had something similar on a VTX several years ago and could not keep it tight (never tried blue lock tight) and finally lost it somewhere. Hope this one is better than what I had then. Keep us posted, if it works for you, I may try one. I like the idea.
