Alan, since there has been so many previous threads on handlebar changes, I figured I just post highlights of my projects. Since the inner fairing only needed to be released from the forks and tilted back for access to disconnect/reconnect and rerouting of cabling, and swap out of riser bushing.....I didn't take any pics of that. Just took the one below of new bars. Right now I'm not sure if it's good night or good morning.:laugh:
First, I was overly optimistic in thinking I could singlehandedly do the handlebar change and Mighty Mite install in one afternoon, but did finish up so soldering jobs. However, due to all the bending and stooping my joints and muscles took a beating.....been heating pad and meds tonight. For today's efforts, age certainly proved it's more than a number.
I did completed the handlebar change, plus removed the stock riser bushings and installed polyurethane bushings. After running the internal cable for the TGS, I decided against attempting internal wiring for the other cables. I did a test fit of PV tuner and will leave it on the right side. Just have to tidy up the cable when I run other wiring. Think I'm going to like these bars and looking forward to getting a ride when I'm finished. I already like like that the center of the faring, gauges and auxiliary dash panel is more open now, just an illusion because the controls are farther apart.
