I found it, #31-1983 in the V-Twin Catolog..No price, but I did an inquiry..Hb
Stainless steel bolts in aluminum and heat will become one. Am I missing something here.
If you want the lowest electrolysis with aluminum you either have to go with galvanized or zinc coated bolts & nuts. If you use either 302, 303,304.or 305 stainless the corrosion of the base metal is marginally increased by the fastener. Because it is considered to be non ferrous metal.Not true, I have a gas grill that you will never get apart, stainless steel in aluminum. Absolutely a one piece boat anchor. Remember SS has steel in it.
I had the same problem last year after hearing a squeak which i couldn't figure out where it was coming from. Turns out that the bolts stripped and had to change the head. After about 100 mile the squeak was back, so off i went back to the dealer. They re-torqued the bolts
and i hoped all was well until i heard (wait for it) that all too familiar squeak after about another 100 miles!!! Off to the dealer again!! Got it back after a week. Don't know what they did but it hasn't loosened in 1500 miles. I hope I didn't jinx myself telling this story!!!!! Good Luck
Hi All,
How is this fix (Zoom Cycle) working for you?
http://www.shopzoom4parts.com/chrome-engine-stabilizer-31-1983.html
Thanks!
This is not rocket science. They have been using these on trike conversions since the 1980's.
Just like the two-wheeled counterpart, the swingarm & axle, transmission and engine when assembled are one structure. The front engine mount & the rear engine mounts allow this assembly to float in the frame. The engine stabilizers keep the engine from jumping out of the frame as well as keep the engine alignment in check.
The stresses created by the trike counterpart from making right and left turns puts a twisting strain on this assembly. The rear trike stabilizer or swaybar helps quite a bit. If you examine the rear engine mounts (under the chrome caps), you will see that they are not hollowed out like the two-wheeler. There is a nylon insert that restricts the rear transmission movement. If it wasn't there then the front stabilizers would snap off even under mild riding. The reason the bolts are sheering are because they stretch and become loose. The spring loaded stabilizer absorbs the stress and stops the bolts from stretching. When replacing the stabilizer use grade 8 bolts and torque 45-50 lbs with red loctite.
My advice is rather than worry about when your bolts are going to break, replace the stabilizer link with a spring loaded one. Issue settled.ThumbUp
Hi Lee,
Thanks for the reply and info. Do you have a part number for the spring loaded stabilizer the would work with the TG?
When I say spring-loaded stabilizer link, I am referring to the urethane dampener type. It's just that I couldn't think of what it was called at the time of writing. I've put them in a vise and they are pretty tough.
I have these 2 in stock right now for $70.00 free shipping to lower 48 states.
When I say spring-loaded stabilizer link, I am referring to the urethane dampener type. It's just that I couldn't think of what it was called at the time of writing. I've put them in a vise and they are pretty tough. I have these 2 in stock right now for $70.00 free shipping to lower 48 states.
would you have the PART # FOR A 2010 TRIGLIDE? and Where I can get one, please.
Are these the chrome units or the bare steel?
I noticed in the price book, V-Twin just raised their price to $83.17.
I will have to raise mine, since I get mine from V-Twin, to $80.00 including shipping to lower 48 states.
These are chromed parts but do not use the included hardware.
