This is the cross stabilizer rod with heim joint on each end just behind the rear axle. It is connected on the right end by slipping over a shaft welded to a bracket welded on the back of the axle housing. The left end is connected to a bracket welded to the frame with a bolt thru it.
I assume the right heim joint is held onto the shaft it slips over with a stud bolt into the shaft. Does anyone know what washers or anything else may go on there before the stud bolt? Since mine came off, I'm not sure what was holding it on.
Any help will be much appreciated!
John in Olney, TX
Stallion #142
John in Olney, TX
Stallion #142
