chester
Banned
What brand tires are you running on the rear and are they conversion specific?
IMHO .... :cxtv: ... most manufacturers use a 205 tire (205/70R15 or 16) for the Harley conversions b/c it has roughly the same circumference as the OEM tire. You can use a 215 tire if the room in the fender is available.
BRAND ... :Shrug: ... I would consider a tire that will displace water quickly with a softer compound for wet-road traction and is quiet riding for the dry pavement. Mileage is not a concern because even the cheapest tires offer good mileage on a trike. Harley-Davidson and others use the Dunlop Signature which is a good all-around tire. 30,000 + miles is easily attained with proper air pressure.
You are 100% correct - I recently replaced my ORIG Dunlop’s with 80 thou + miles on them, still had tread but figured at 8 years (2010 HD trike) old I better replace them!
