Rear Tires
Dunlop Signature
What brand tires are you running on the rear and are they conversion specific?
IMHO .... :cxtv: ... most manufacturers use a 205 tire (205/70R15 or 16) for the Harley conversions b/c it has roughly the same circumference as the OEM tire. You can use a 215 tire if the room in the fender is available.
BRAND ... :Shrug: ... I would consider a tire that will displace water quickly with a softer compound for wet-road traction and is quiet riding for the dry pavement. Mileage is not a concern because even the cheapest tires offer good mileage on a trike. Harley-Davidson and others use the Dunlop Signature which is a good all-around tire. 30,000 + miles is easily attained with proper air pressure.
Tires
You are 100% correct - I recently replaced my ORIG Dunlop’s with 80 thou + miles on them, still had tread but figured at 8 years (2010 HD trike) old I better replace them!
:cool:
:cool:
Just put 215's on BF Goodrich Radial TA had 235's on it it steers so much easier Also moved tour pack back which positions passenger weight as well as rider weight back a bit which also takes weight off of front wheel. Put avon trike tire on front, 24 lbs rear tires 42 lbs front tire 10 lbs front forks 70 lbs rear air bags. now it rides awesome very minimal wobble
Ron A
