Protect your fenders.
i FINALLY GOT AHOLD OF A LIVE BODY AT THE DIRECT PH. #651-737-6501.
THEY TOLD ME THAT THE APPLICATOR NOZZLES ARE CAUSING THE PROBLEM AND THEY ARE SENDING ME AN UPDATED APPLICATION KIT THAT IS SUPPOSED TO TAKE CARE OF THE PROBLEM.
I AM A LITTLE HESITANT TO TRY THIS NONSENSE AGAIN. I WOULD HAVE PREFERED A REFUND!
i DON'T KNOW THE DIFFERENCE BETWEEN THE TWO NOZZLES, BUT BE CAREFUL YOU ONLY BUY A RECENT ISSUE OF THE PRODUCT.
IN THE MEANTIME I GUESS I WILL GO OUT AND MAKE LIKE AN ONION PEELER! then YOU HAVE TO CLEAN OFF ANY RESIDUE WITH AN AMONIA BASED WINDOW CLEANER.
I have a new posting under general disscusion about paint defender nozzles
Don't you use it on your bike or bikes? Did you use pre-cut film on your SS or did you or an installer do a custom job from a roll of film. I want to use it on my TG, but I want different coverage than the pre-cut and I'm not sure the film will make some of the tight curves. I may have to try this spray stuff after they sort out the nozzles.
I had an installer install mine and I am very pleased with it. You are correct about the coverage between a kit and what an installer will cover. The installer can cover most curves and bends.
PBS's Motorweek gave the 3M spray a good recommendation.
Also in Chicago's sunday paper's auto column gave a big thumbs down on bras for cars.....and I would assume for bikes also.
I feel why pay $23K to $32K for a bike and then hide it under black naugahyde. I use the 3M film, but will definately try this spray. ThumbUp
Flyboy7312
