Nitrogen filled tire
I tried it and it was so so, too make a long storie short just go with RIDE ON and you are good for the road. BE HAPPY BIG DENNY
Ride-On tire sealant has made a huge difference in how often I add air. At least 50% of the tire is sealed which means less air to escape. The only times I add air now are seasonal changes when going from hot to cold in winter. Basically once a year. All the other times I check I'm just letting air out. So unless the bike is handling odd I just don't check anymore. But old habits make me check from time to time. So I check and go, crap, it don't need any and I just let some out. I know the tire normally isn't losing air so why check? Again, old habits. I'm learning though. So I totally understand the nitrogen thing. But the added puncture insurance out weighs the nitrogen. I just wish I could get the Ride-On on all the inner surfaces instead of just the outer ones. Then I'd have no need for nitrogen at all. I'm sold on Ride-On just like others are sold on nitrogen.
I haven't used Ride On. I have experienced other tire sealant's in the past. Those are a mess. Once those old sealants dried, almost impossible to remove a tire to replace. For those of you who have used Ride On, does that product stay liquid and have you changed any tires since starting to use it?
Thanks.
nitrogen filled tire
sales gimmick.works for nascar but in real life its not needed.car dealers try to sell it .dont n
eed it,when your traveling on road ,try to find it at your mom npop gas stations.use pump air.its free or 1.00 for pump to work
Thanks.
I've had several tires changed and it stays in a thick liquid form. If you run low tire pressure that causes the tire to get hot it will eventually harden or turn to a powder. I've had one tire that got a huge hole that Ride-On had no chance of sealing because it was so large. That tire got so hot with me riding a completely flat tire that the stuff turned to powder so I'm not sure if it got hard then powder or just turned to powder. But at any rate it's heat that would change it and low inflated tires might just do that. When it's in liquid form it washes right off with water. Dried it might take a little more elbow grease but water is all it takes. I have had tires sealed with the stuff when I got a darn finish nail in a brand new tire and it just left it alone rather than dig it out. Every now and then I'd see a wet spot and that was all. I think they suggest you remove anything that gets in them though. I just know now that even if you miss seeing a nail or screw the stuff will continue to seal. So I'm sold on the stuff. Hope this answers your question and possibly others.
Reality2025
