Help with Carb jetting
Devon Donk
1+ Posts
Jun 10, 2023
4
9
Cullompton,Devon,UK
I have a VW trike. I have just got a new pair of weber 34 ICT carbs. my question is what size jets should be in them.the engine is from a 1974 beetle 1600cc twin port.the jets that are in them from new are:-
55 idle
150 Main
F78 Emulsion Tub
175 Air corrector
175 needle valve
40 Pump jet
will they be ok and what difference would changing them make.
Do I need a balance tube from one to the other
Many Thank to All
I have not ever tuned a set of dual single barrels...... I always go bigger.
A lot of folks talk bad about itc's ...... I don't get it..... just a carb.
Dual singles like to idle on only two cylinders. The balance tube helps, but if everything is perfect it don't make a diff. But it does hide or smooth out tuning problems. I would not hesitate to use a balance tube.... it would have to be fairly large ID though.
Here is a link to some help I googled up for you.
https://www.wayoutwestie.com/aircooled-tech/running-weber-icts-on-a-vw-aircooled-engine/
There is a lot of info on there very good. thank you so much
Eddienorman
