handle bar bushings
leonard
70+ Posts
Oct 30, 2014
80
39
Kearney, MO
Leonard
when putting on taller bars on your trike did you replace the bushings with the heaver ones. On a 2014 triglide
I did...With the rubber bushings and the taller bars they felt a bit mushy. The down side is the bars do shake a bit more at idle. Just my opinion.
jc
It's worth the shake (which only happens when stopped). The rubber bushing wear out much sooner, and the whole fairing would have to be removed to replace them. Unless you're a do-it-yourselfer, that's going to cost $$$ to do.
Just my .02
bushings
Just my .02
which bushings did you use?
if I had mine apart for handlebar change I would replace bushings with good quality urethane bushings ,,, hey its apart ya know
get err done!!
magoo
Ron A
