leonard
70+ Posts
when putting on taller bars on your trike did you replace the bushings with the heaver ones. On a 2014 triglide
which bushings did you use?It's worth the shake (which only happens when stopped). The rubber bushing wear out much sooner, and the whole fairing would have to be removed to replace them. Unless you're a do-it-yourselfer, that's going to cost $$$ to do.
Just my .02
Nylon.which bushings did you use?
