Battery Life
I replace mine every 3 years, the Florida heat just eats them up. Batteries in our car are the same way.
Batteries on mysterious black boxes some last six months some could last 10 years no matter what anybody says there is no set time. What would I do? The second time I hear, click click click and have to put a booster on it to start the machine that’s the time I order a new battery.
Indeed Bob Indeed :D
I have been getting 3 years out of the Deka Big Crank batteries in a 15 tri-glide. My other bikes i always got 5 to 7 years ,but they didn't have all these electronic gizmos. Kick start and jockey shift all the way.
I'm a believer in leaving all my rides on a tender, I actually prefer the Noco Genius. Not mentioned yet, that I found it interesting I got a ECM code after disconnecting the ground to do some work and had to clear it to get the check engine light out. All hell broke loose when I pulled a rear wheel off, Still getting used to these high tech vehicles!
The newer bikes with the electronics are notorious for throwing codes when battery gets low or is changed. I document codes ( just in case)clear codes then ride and see if they come back .
My battery (died) did the same except I was on a TRIKE rally in Vermont last season... I was lucky one of the attendee's had his truck and I went to a NAPA auto store and purchased a new battery... replaced it in the parking lot of the hotel...... THANK YOU DOUG, FOR THE USE OF YOUR TRUCK, TO GET THE BATTERY if you are reading this
5/26/24
My experience is that vibration kills batteries in Harleys. When they die due to vibration it is suddenly with no warning. I changed mine every 3 to 4 years.
Delverc
