I replace mine every 3 years, the Florida heat just eats them up. Batteries in our car are the same way.
Same for most batteries in central Texas. Mine are notorious for failing just after the warranty period ends!I replace mine every 3 years, the Florida heat just eats them up. Batteries in our car are the same way.
Indeed Bob IndeedBatteries on mysterious black boxes some last six months some could last 10 years no matter what anybody says there is no set time. What would I do? The second time I hear, click click click and have to put a booster on it to start the machine that’s the time I order a new battery.
The newer bikes with the electronics are notorious for throwing codes when battery gets low or is changed. I document codes ( just in case)clear codes then ride and see if they come back .I'm a believer in leaving all my rides on a tender, I actually prefer the Noco Genius. Not mentioned yet, that I found it interesting I got a ECM code after disconnecting the ground to do some work and had to clear it to get the check engine light out. All hell broke loose when I pulled a rear wheel off, Still getting used to these high tech vehicles!
