Anybody Carry A Battery Jumper Pack With Them?
Had a thought now that hot weather is finally creeping in. There isn't any issues with leaving a battery in your trunk on a 2 week trip in 90 degree weather is there? Would hate to have it burst into flames on the road. Could be a real nuisance.
I doubt you will have any problems with it ( the jump pack)
I had a buddy that had a bad regulator on a Softail Heritage, I could have fixed it easily for him, he instead carried a battery in his saddlebag all summer:p
You have to have the attitude that anything can happen so it would be prudent to be cautious like if you’re carrying extra gas I wouldn’t keep it next to it 🙄..🙄..
In my nearly 60 years of riding I have never experienced a dead battery. I have however had to get a couple of others started. One was a Goldwing whose owner had let the cable end corrode thru and break off.Since this was back in the day of pull tabs I found one in the parking lot crimped the tab around the wire and ran the bolt thru the ring and it got him home. Now that battery packs are small enough to pack, I am glad you elected to buy one for yourself. Hopefully you will never need it,I have not needed mine since I got it.
I have used mine to jump other peoples vehicles off and my truck, it seams my 2018 truck does not like sitting for 2 and 3 weeks without being ran. I put a solar charger in the window to see if that helps. I do carry my NOCO in the bike when we go for a ride with a group.
A bad battery can kill a regulator rectifier. A bad regulator can kill your stator. Metal particles attached to the rotor magnets can eventually kill a stator. One test is a regulator bleed test. Separate the stator connector (it comes out the front bottom of the primary case)from the regulator connector.Key off. You can use a simple test light but I like a computer safe logic probe. Around 10 bucks at Harbor Freight I think. Connect to a good ground then touch the probe to the regulator connector terminals. If the probe lights green or bulb lights- voltage is flowing back through the regulator. Bad JuJu. Voltage should only flow towards the battery. There are 3 positive diodes and 3 negative diodes. Those also need to be tested.
I've carried a motorcycle sized jumper cable since 1988 when I bought my first Harley. Then about 5 or 6 years ago I had a bunch of "Chrome Cash" I needed to spend, and Harley just came out with their own battery starter/jumper unit. So, I bought it (20% off sale). I just took it out last week to check the charge. Guess what, it's still holding a 75% charge. Haven't use either one yet.
Back in the early 80's I was NCOIC installing and repairing GRIATS- ground infantry attack systems( pronounced gritts). These are the power units that make the targets pop up.The power source was a marine deep cycle battery for each unit. I was hungover,hot,tired,pissed and being eaten alive by black flies, and the unit training on that live fire range was due onsite by 1300 hrs. Right next to each power unit I installed a hoffman device.A tube like device that I inserted an electrically fired charge in, that simulated a grenade, LAW, M203 etc strike or launch and also smoke grenades.I noticed that the cables would be just the right size to make mini jumper cables for my Superglide. When I got back to the shop that night I pulled 12 feet of cable off the bulk reel, cut it in half and crimped heavy duty midi alligator clips on the ends. Still have it somewhere in the garage.
Almostagamer
