Clutch recommendations
Trying to look up barnett kit can't find fit for 15 triglide pn#?See one that should but match to bike says no
The stock ones are actually really good. I took mine out of a 07 with l8me 90000 miles and it looked great. I was upgrading to a bigger motor and installed a Barnett with a stronger spring but I think I really only needed a stronger spring.
I do ALOT of mountain riding in eastern OK and Ozarks bikes at 28k not slipping yet but softening so planning ahead stock isn't gonna last past 30k w my riding style.
Most of my first 60000 miles was In The NC mountains and very aggressive… I put 60k in the first 3 years I had the bike. Barnett makes a badass product, you will feel it on the first ride when you let the clutch out for the first time, it grabs.
Soo I was concerned, was told if when warms up clutch getting soft meant u need a new clutch. I ordered new clutch from Barnett. Well I was concerned about part numbers so called Harley to double check. Talked to mechanic because I've w any clutch on anything I've have u notice the dragging first all the time. This wasn't the problem, mine was fine until prolonged use. So on hydraulic clutch when it warms up if clutch get worse flush your lines don't order new clutch. Haven't flushed but I'll let u know.
jhlesher
