You will like the linkage, Stock SUCKS:p
Jac
I have this one
33801-09_TT.tif
You sure are right !!!! This thing shifts a lot easier now and finding neutral is even easier. Thats the same one I got!
Foot Pegs
Let me preface this by saying that not only is this my first trike but also my first Harley. I made the jump from 25 years of Goldwings mostly due to the way you get treated by the Honda dealerships and secondly because I wanted a trike that was built by the manufacturer, not 2 or three entities for the final product. I have a 2022 Tri Glide that just broke 1K so I am early in the learning process. I like the Kurakyn (sp?) switch blades but to be honest over the years I have been disappointed with their chrome products. I am looking for a set of highway pegs and it looks like with the Harley I have to purchase the mounts and pegs separately. Any suggestions and why you like them would be highly appreciated.
Thank you in advance from the new guy on the block :D
The One thing I can say about purchasing chrome products from aftermarket companies instead of from Harley is that Harley knows chrome I’ve never been disappointed with the chrome products from Harley can’t say that with aftermarket chrome…
Installed the JES fork wings/fangs find out tomorrow how well they work.
Those fangs are known to block airflow to the engine.
Kurt
Yes I took it out today for a short ride today and that appears to be the case
Find out tomorrow with a longer ride
They do a good job at blocking air to the rider, reducing buffeting. They also block air to the engine, typically increasing engine temps around 20-25 F. These engines already run too hot for their own good, so looking for a different way to reduce buffeting and cool down the engine instead of making it hotter.
A Tank Lift and Cooling Deflector Wings will cool down the engine about 20 F, instead of heating it up about the same. They will also reduce buffeting. NOT as much as the fangs, but quite a bit for most riders.
Yes I have noticed the heat on the 2 rides I have done with the Fangs installed they are probable coming back off
its been cool here lately so I am sure I havent over heated the engine yet
I already have your Cooling Deflector Wings and floor board extensions on it an a taller windshield along with these fangs
It seems to be rideable now but not if the engine is going to get hotter its already hot enough on my right leg and the wives leg
plus I dont need any heat induced engine issues
I am about done with throwing money at this dinosaur
A Gold Wing trike without a warranty is looking better an better or possibly a Can AM Spyder
I have ridden on the street since I was 15 in them 49 years I have owned at a minimum 35 motorcycles of which 4 were Harleys
including this one.
this is my 5th trike 3 were VWs 1 was a Goldwing
out of all of them bikes/trikes. I like this thing the least !
Thanks, I do like the quality of the Harley products but so far haven't seen a design that I like. Guess I am a persnickety old person :laugh:
Dwayne I was watching an infomercial late last night and there was this pretend to be doctor all Dressed in white with a stethoscope hanging from his neck who found that if you grind up the bones of a sardine and add 3 petunia petals it will cure Persnicketiness ….😉😉.. ..
Persnicketiness; Look that up in your’ Funk and Wagnalls …😁..
:laugh::laugh::laugh:
Got the tank lift , tank wings , tree baffle and fangs . Run them all year . 200° oil temp and 220-230° head temp . Oh forgot , removed right side air scoop .
Interesting, it seems most folks removed the left deflector and kept the right side to shield their leg from the exhaust. Did you test or randomly remove one?
Kind of a common sence issue . If both scoops are on , the air butts each other , as it has no place to go . Removing one side will allow the air to flow out and hopefully help the rear cylinders heating issue . Does it work ? Hope so . I lived 74years on common sence and knowing that you can’t compress liquid .
Sounds like you’re getting a little riled but that’s cool, I have pretty thick skin. I didn’t ask about one deflector verses two, but about left verses right. I have one on the right thinking I would shield my thigh from the exhaust. After I read your post I considered maybe pulling in possibly cooler air from the left may better cool the cylinder. That’s why I asked if you had compared sides. I’m not sure what you were referring to about compressing liquid but if you meant that pulling air from both sides would create positive pressure behind the rear cylinder, then I concur.
Ordered the oil filter relo and oil cooler combo kit from DK Customs and a manual bypass valve from Dennis Kirk. It should all be in early next week and installed while I'm off for the Holidays. I have already installed the reusable oil filter. I don't think I have anything left to buy from Kevin. LOL.
Thanks to member Koolbreeze who recommended the flashing tail/brake light bulbs from Amazon! Got those installed today, and they are much brighter than stock and when you apply the brakes they flash three times, then stay on steady.
Also installed the H-D “trunk guard”, aka bumper, to my TG, today. Might save me money from careless backing in reverse. I also like the “look” of the bumper.
SOSMentor
