the previous owner had all the tires fille with nitrogen, I know aircraft runs nitrogen. Does anyone here run it?, pros & cons?
I fill them up with about 78% nitrogen....I find that works best for me...:Shrug:
Pretty funny![]()
What I learned is that plain air will leak right through a tire eventually. It's the molecules other than nitrogen that pass through. Nitrogen molecules are bigger, so they don't pass through the tire rubber. If you fill with "pure" nitrogen, you won't lose air over a long period of time. It's also more stable, does not expand as much with heat, that's why NASCAR teams use it. Some Costco's have nitrogen.
Or, you could just check your tire pressure more often.
A waste of money
A waste of money
Nitrogen in the tires were A gimmick started by the Florida new car dealers Association many years ago this way they can convince all the old gullible retired people that they have to come back to the dealer and pay for nitrogen in their tires every time they Needed a top off of nitrogen ����
Another gimmick to separate dollars from your wallet to theirs. Tried it years ago,not worth the $$. Also the more you check the pressure the more of it you lose.
Thank you Jim , well explained :clapping:
Every thing was fine till the idiot light era arrived!
Me tooI also change the air and make sure I have the air for the correct season installed. Ie: Summer air, Winter air, etc
I just changed a tire on a rim that had been mounted since 1999. Boy .... I never realized how much fresher the air is now compared to how that air smelled.:qpnmt:
That's funny Jim!
In a past life, I used to dismount tires at a local used car parts recycling yard where I worked. The first time I smelled the rankness coming out of a tire when it was deflating, made me gag.
After awhile I got used to it but it made me wonder, to this day, what made that smell since it was only "air" in them....:Shrug:
That's funny Jim!
That's funny Jim!
You are correct sir! It's more stable because it's much dryer than regular air.The reason NASCAR tires are inflated with nitrogen, rather than the normal air we pump into our tires, is due to the increased stability under hotter temperatures that the gas exhibits. It allows the tire pressure (Up to 50 pounds per square inch) to remain constant throughout the race regardless of the temperature, which can reach 200 degrees Fahrenheit. (from NASCAR's website)
