Should I be able to Start while in gear?
hardwickbv
1500+ Posts
Gold Member
Mar 5, 2017
1,942
705
Mitchell, IN
Bob
Should I be able to start my 2017 Tri Glide while it is in gear with the clutch pulled in?
I have read the manual and it doesn't recommend it, but leads me to believe it should start and I have not been able to without putting it in neutral.
May be a safety thing but is a pain should you kill it a light or somewhere else.
Bob
Yes you can as long as you pull in the clutch lever and apply pressure to the back brake. It will start.
Nuc
I have to depress front brake lever to start in gear. When I tried the foot pedal I got nothing but a dirty look. It is difficult to look like Joe Cool when you are sitting in an intersection on a stalled Trike. :D
I also use clutch & front brake lever to start in gear.. Never tried with foot pedal.. have to check it out
Bob
I never had any problems starting the bike this way.
AlanMatamo
