88 Blazer Trike
reply
i will definitly agree with vw bug. that setup will work just fine.......i've noticed that when using smooth side w/p pulleys....they give more degrees of belt wrap....less traction than with grooves, l suppose.
Great,
Once I get the Trany cross-member done I can start on that
This weekend is tied up with Honey do list and PM on my other trike
started mocking up the altenator
The stock bracket puts it up to high
if I make my own bracket I can lower it 2 inches
Not sure why all my pics got turned on their side
Had issue uploading another pic also
fabricated the cross member yesterday
for now it has 1 bolt on each side
later it will have 2 on each side
need to weld some gussets on the underside on the bracket that is actually welded to the frame
crossmember
bob.....what are your plans for the humped up crossmember that is above your new rear trans.mount??? .....realize it was/is needed to keep frame in alignment. body mnt. seat mounting or what.....just curious.
In front of the cross member will be the front seat (above the trany)
Behind that will be the back seat. (will have a plate over the drive shaft for Butt protection)
Then the gas tank and at the end a truck bed with a nice wood floor inlay
My wife wants a dash panel so attached to that cross member will be some type of stand with a platform on top. Not sure what will go in her dash yet
you are moving right along, more than i can say for my projects...no idea if its been mentioned or not...but it looks like your pinion may be up a tad... should be within a couple degrees of the trans..if not it will vibrate...i think you can buy wedges to help or cut n re-weld the saddles....
this a great explanation
Not for a Double Cardan/CV shaft.
The Pinion angle is different when setting them up
reply
good info on drive shafts.....sounds like that crossmember will be put to good use! i like that idea of a dash for the passenger, could be a backrest for the driver and used for a hand hold for the passenger to get into the their seat. speakers mountings ,electronics etc. also a partial windbreak for the passenger. i am enjoying the build !!
I got the bottom part on the alternator bracket made. Now need to make the adjustable arm
Its made out of 1/4 flat and 1/2 rebar support
I like the look but wish I had justification to put another one on the other side to balance the look out
Instead I will put a dummy pulley on the other side
set an old seat on it.
I may have to rethink my seat design
I was going to have front seat, back seat, gas tank, truck bed
Basically I will have to move the front and back seats back some and move the gas tank to a different location and/or lengthen the rear for the truck bed
yeah....maybe move back 18" or so. gotta have room for legs and feet. if headers go straight out and then down over frame, your feet could be between headers and block , but could get warm.....other wise either side of tranny or bellhousing.....you may have to decide on your exhaust system before the seat location, just saying.
I was thinking the same thing
moving forward
looks like plenty of room for radiator and neck/fork. will you use steering link rods or long handle bars?
The plan is to have the radiator under the truck bed in back and channel air to it,
I was thinking of using a steering link setup. I have seen a few of them and I am told they work well.
I personalty like the long handlebar look better but I have to balance the look with the function
Now that I moved the engine/trany forward I will have to change my pinion angle.
Since they were moved forward and I will be using a double cardan style drive shaft I will have to lower my pinion to point at the trany output shaft again.
I have not figured out how much I will have to lower it yet but I will
since I moved the engine and Trany forward I had to make a new Trany mount
I am keeping the old cross member because it is the right height for the back seat area
This is a quick mock up at 36 degrees will do a better mock up later
Not the wheels I will use just something I had around to stand up there
I like the fat car tire but not sure how well that will work
I like your thinking in that the "fat car tire" out front will serve you best.
Engineering a wheel/brake mount for the stock GM wheel isn't rocket science, but it is critical in getting the trike to handle the way you want/expect it to. Looks like that's what your after in the "mockup"?
In my opinion/for what its worth, (not much), typical motorcycle fork or leading link setup might be easier to fab from scratch, but maybe you have that covered already...?
Traction is your/our friend, on a trike!:clapping:
ditto
ya ditto on the fat car tire.....that tire will soak up a lot of small bumps.....plus w/ heavier engine, fork springing will need to be stiffer.....so that tire area will be more important than ever for ride quality. my .02
:clapping:
I have been scouring the internet for info on setting up a GM wheel for motorcycle forks but cant find much
I have been researching Leading link forks I believe I will go with some form of that
I want to keep my wheel base as short as I can
Right now my wheel base measures at 9 ft 2 inches
That is longer than I wanted but it is what it is
Stitch61
