when i posted the pictures this morning i didn't have time to explain them , here goes.picture 1 is 2" pipe split to fit around the voyager kit.this will hold the bottom of shock. also had to trim fiberglass to alow for this to fit.i trimed 5 years ago has not been a problem.# 2 picture i made these to compress shook 1" when mounting shocks. #3the drawing of the parts that i made.#4rear enging guards, i cut them off at 21/4"long and then bolted back on bike then mounted 3/8" plate to engine guards i also put solid bar in each of the engine guard for strength and then welded them together.then i drilled 11/32" hole and threaded 10mm. the shocks have a 10mm hole each end.#5 this is the style shock i used,these were to long so i went with 7" ones. #7 this is the right side as it is mounted on bike and trike.#8 is the left side. i also used self locking nuts on upper and lower shoch bolts. i usrd the self locking nuts without the nylon insert because they a re shorter. if any one has any questions let me know.
