when i posted the pictures this morning i didn't have time to explain them , here goes.picture 1 is 2" pipe split to fit around the voyager kit.this will hold the bottom of shock. also had to trim fiberglass to alow for this to fit.i trimed 5 years ago has not been a problem.# 2 picture i made these to compress shook 1" when mounting shocks. #3the drawing of the parts that i made.#4rear enging guards, i cut them off at 21/4"long and then bolted back on bike then mounted 3/8" plate to engine guards i also put solid bar in each of the engine guard for strength and then welded them together.then i drilled 11/32" hole and threaded 10mm. the shocks have a 10mm hole each end.#5 this is the style shock i used,these were to long so i went with 7" ones. #7 this is the right side as it is mounted on bike and trike.#8 is the left side. i also used self locking nuts on upper and lower shoch bolts. i usrd the self locking nuts without the nylon insert because they a re shorter. if any one has any questions let me know.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
