Ok ive gotten about as much life as I can out of these Michelin Hydroedge tires. Plent of tread, just starting to crack.
What out there now for rain shedding 15 inch tires
I've known such people … until they tried it.Rake... Never had it...Never will...
Don't know who it was asked of …. but it was I who mentioned the B F Goodrich Radial T/As. The Lemans SR 215/70R15 was a full inch narrower than the Dunlop GT Qualifier 245/60R15s that came on it and in the kit from Lehman. I even added 1/2" spacers and longer Morosso studs to get narrower tire back out near wheel opening. I saved 4 pounds per tire in rotational weight at outer tread diameter and same 4 pounds per tire …. 8 pounds total in unsprung weight. I've been shopping, I like the looks of the raised white letters on this trike. I really liked the symmetrical looking "LEMANS SR" lettering 180 degrees apart on them as well as the smooth sidewall rubber. I was just looking at Tire Rack, it would cost more, but I might go back to the fatter original size 245/60R15 and pull the spacers off and shorten the studs by 1/2". Would cost a little bit more, but good chance they would be the last ones I bought for the trike, and in BFG weights, only 2 pounds difference per tire (before, was difference in a Dunlop GT Qualifier and these Lemans SR tires, not the same manufacturer), virtually same OD too.Goodrich t/a, any reason you went that wide
I'm thinking of a pair of B F Goodrich Radial T/A (s) in 215/70-15 RWL. I like the looks and the times I've run them on cars, I was extremely happy. Good wear too.
LOL...Tries a rak, my dad had one on his trike.... I hated it. totally hated it. it was waaaay to twitchy for me
That surprises me a little. They never had a bad rep back in the old days, but I've read and heard others say they aren't so good now a days? Maybe they are changed in compound, etc? Did I read someplace that Coker owns BFG now? I will stay with the P215-70R15 size though. Looking just tonight as I bled & adjusted the brakes, these Leman SRs are down to 4/32nds.Indeed, B.F. Goodrich Radial T/A's are great on perfectly dry pavement. It takes very little water at all on the road to bring painfully to bear the error in that line of choice.
