I just found out how to start my 014 in gear. You have to pull in both the clutch and brake levers at the same time. (just in case you stall at an intersection because your actually in 2ed gear when you though you were in 1st)
Are you sure about the break?? My '09 and '11 will start with the clutch pulled, doesn't seem very safe if you have to be at a complete stop to re-start
You can use the foot brake if you are more comfortable than using the lever. The brakes have to be applied in order to start it. Found it the same way stalled at a light wrong gear horns blowing behind me.
It's clearly explained in the operators manual!
My 2013 will only start in neutral.....
It's that weak left paw !pepper
