rear tires
Nov 23, 2014
18
Elmwood, Ne USA
I am new here. I have a 96 Goldwing SE with an 09 Roadsmith trike kit installed. I have a problem with rear ties!
The original tires were bald in 22000 mi! At 11000 mi I noticed they were worn bad on the inside! had them reversed and 11000 mi later they were bald! Replaced them them with new 100 thousand mi rated tires and they are worn bad on the inside! Has anyone had a problem like this. If not how many mi do you get out of back tires on your trike? Thought when I got the trike I would never wear out the back tires.:mad:
Not smart enough to know what, but ya got a real problem there. My 08Wing/Roadsmith has 30,000 on the rear tires and they still look new. Think I would find a good Roadsmith dealer and get them to look at it. Also try posting on Roadsmith's thread on the forum. They are pretty good about helping out. GOOD LUCK Ride Safe
Hi Dirtman,
Sounds as if you might have an issue with the suspension set-up on your trike. Whether you have the air shocks or the adjustable coil-over shocks, there are some possible solutions we can offer. If you would, please call the factory at 800-331-0705 and we can discuss the options with you in detail.
Thanks,
The Roadsmith Team
Flyboy7312
