Rear bearing mileage
Rogue1
400+ Posts
Oct 8, 2018
414
315
Ramseur NC USA
What can I expect for mileage out of my rear wheel bearings? Twenty-three thousand Miles right now and am considering new bearings and bearing retainer plates from DK. Everything is fine right now no wiggle, wobble, or Shake of any kind. So you know what they say, if it ain't broke..........
2019 TriGlide.
2019 TriGlide.
I don’t know what you can expect of the first set of wheel bearings but my experience with changing wheel bearings on side-by-sides and ATVs that when you put the second set on they don’t last half as long as the first set sometimes not even a third….🤔
2019 TriGlide.
40,000 is the most mileage i have ever gotten, but my bearings were still good, like you said "if it ain't .....
I dont think it is so much a mileage thing
There are more factors, like how much end play you have, how much riding in rain, noise, and others are factors
Another thing to consider, these are sealed bearings, not all bearings are created equal
Just my 2 cents
Just my 2 cents
My riding is done in adult miles. Only ride in the rain if I get caught in it which is rare. Everything appears to be tight back there but I do take long rides and I don't want to get caught in the middle of Bumfuk Egypt and have them take a crap on me
Changing the bearings and adding the DK Customs plates will be a big plus IMO
2019 TriGlide.
Well if you saw my cheap HD bearing plates when they came off my one year old trike ,you might change your mind. I have DK now on my rear axles. Huge improvement over flimsy HD plates. These new plates are near twice as thick as HD. Glad I changed. Trying to remember, but I think there was less than 15k on the trike & those plates were scarred bad already
Just my 2 cents
I’ve poped the seals out and repacked them with water proof grease . Re sealed and good to go . Do it by yearly with my mower deck bearings also .
Amen to that, same here. I do not trust them to be greased good when made
Too many times I see not enough grease and or grease that looks like Vaseline, only thinner
The book says a minimum 25ton press to remove and install the bearings. Really? I guess my 12ton press won't do it.
i dont understand... are these these made from crap to start with??
car rear bearing go on and on,,,, and a trike has a fraction of the weight
On the rear bearings on the HD Trikes it is not so much the bearing failing as the bearing retainer plate. They (the bearing retainer plate) are made of stamped pot metal.
Here is a video showing what I'm talking about.
grimpen
