2010 Honda Goldwing Champion Trike, Rear bearing
Jul 30, 2021
La Blanca, TX
I am from the south Texas area, just a few miles to the Mexican border.
Anyone has replace a rear bearing on a Honda GL 1800 Gold Wing Champion trike.
I have called the Arizona company that has taken over the Champion trike. No luck.
Anyways, seems like I just can find the bearing. I have read that before 2006 trikes could have used toyota, VW parts etc. On the 2010 I am not sure. What to look for. Any suggest on the topic.
Bearing dimensions: ID: 39.8 MM, OD: 76 MM, W: 27.9 MM
Any suggest are welcome. Thanks on taking time on this matter.
Oliver does not the bearing have a number on it? Should be able to read that number and find a place that sells them.
Ted has given you good info here
You may also try a good Auto jobber ( Napa comes to mind)
You have the dimensions, many jobbers can pull info from SKF, and Timken with access to bearings thru your specs
Good Luck
Industrial bearing suppliers are another good source. I Googled Bearing Suppliers, LaBlanca, TX and got several local results. All they usually need is the numbers off the side of the bearing or the bearing itself.
FlintM
