Radiator and/or cooling removal
Mar 17, 2010
32
2
The fan blade on my wife's stallion has come loose from the motor. Has anyone changed and/or removed the radiator and/or the cooling fan? If so, could you give me some guidance on the procedure? I have removed that portion of the exhaust that sits directly under the radiator. I have also removed what appears to be the bottom support where the rubber radiator support mounts into. Have also removed the six bolts at the bottom of the fan cowling. The radiator remains fairly stationary after this. Have not drained the radiator or removed the hoses as I am not sure what all needs to be done. There are two bolts in the floor of the trunk, do not know if these play a part of not. Any assistance would be greatly appreciated.
For general information TMS has provided the information that the cooling fan and shroud are from Vintage Air. That part number is 32161-SHF.
Again thank you.
Do a search of the Stallion section. I remember one person posting something about removing the radator, but I do not remember much about the post. Sorry can not be of more help.
Stallion Fan
I can't find dates where items were posted so if you have found answer, sorry to bother you. Otherwise we changed my wife's fan this summer and I can tell you a little more about it.
JStogner
