Burnerboy
2000+ Posts
I just replaced the radiator fluid in my wing/very easy procedure
All you have to do is: Removed the right hand side glove box (two phillip screws and two pop rivets and then carefully removed the plastic strip ) and pop out box, there you will see the radiator cap... DO NOT OPEN YET,
DO WHEN COLD!
A. Then look above the oil filter, and see a small 8mm bolt, remove that bolt, and have a pan under to catch dripping fluid
B. Remove the cap and allow fluid to drip into pan
C. (besure to have also purchased a small copper O ring to replaced the used one, on the bottom 8MM bolt)
D. Replace fluid with Honda Blue color anti freeze...(3 quarts)...This will be very slow process, pour very slowly, little at a time, and let it drain back into the radiator until full,
E. Start engine and allow to run till fans come on,
F. Replace glove box, the plastic strip, and enjoy your next ride, just knowing that you saved $100.00 labor
Ronnie
DO WHEN COLD!
Ronnie
