G
gerald martin
Guest
filter relocator
mine is a 2015 freewheeler. Another question. Will the stock oil cooler lines work with your low mount fan assisted oil cooler on my freewheeler I do not want to use the jagg adaptor as I have had a bit of trouble with them before and I already have the stock adapter on the bike now.Yes, if you have a '13 or earlier that comes with a factory oil cooler, then you do just that.
Remove filter from current location, and put the adapter in its' place. The install the oil filter relo and put the filter there.
You do not touch anything with your factory oil cooler.
