Oil Filter Relocation & Dual-Cool Oil Cooler
filter relocator
Yes, if you have a '13 or earlier that comes with a factory oil cooler, then you do just that.
Remove filter from current location, and put the adapter in its' place. The install the oil filter relo and put the filter there.
You do not touch anything with your factory oil cooler.
mine is a 2015 freewheeler. Another question. Will the stock oil cooler lines work with your low mount fan assisted oil cooler on my freewheeler I do not want to use the jagg adaptor as I have had a bit of trouble with them before and I already have the stock adapter on the bike now.
Oh man, sorry...forgot about the post '13 Freewheelers.
Yes, you can use the low mount fan assisted oil cooler with the adapter you already have. I don't believe the hoses you already have will work, because the hose barbs on the cooler are in a different location.
However, we will send some hose with the cooler that you can use with it and with your existing adapter.
We do not have the cooler without the adapter on the website, so if you would like it, call or email the shop and they will fix you up with it (at a reduced price because of no adapter).
shawn.s.prescher
