Just got this trike and would like help with the lifting points. It has the water boards on the sides. Have a long lift with front extension. 1600 pound capacity. Thanks for any help.
Anywhere under the motor but behind the oil filter as @geol points out is fine. It wouldn't hurt to use a small block of wood between the motor and the jack. Honestly I don't do that but it's not a bad idea. Just make sure it's evened out.
Also in the rear, anywhere under the plate that the rear differential is mounted to is fine. You just don't want to try lifting using the arms to the right or left of the rear differential.
