GW Motortrike Adventure.. Rear Tie-down Points ???
paws
Just Killing Time...
Gold Member
Oct 22, 2011
5,395
3,711
Kerrville, TX
Carla
Hi All....
Underneath the rear of the GL1800 Motortrike Adventure kit..... where would you best hook onto to tie down to the trailer? I have an Aluma TK1 trike trailer.
Would it be the solid frame piece that the bike's trailer hitch is welded onto? I don't see any place else to place the strap hooks except on the bike's trailer-hitch bars which are welded to that kit frame bar... and I don't know if they would be strong enough.
The front tire has a Condor type grab-chock and then a strap will be wrapped around the wheel tieing it to the chock also.
I've pulled this same trike/trailer before several times - just did not partake in the actual tie-down operation myself.
Any info appreciated....need to hitch up Saturday afternoon.
Thanks guys!
I've always used a strap on each rear wheel. Most wheels have slots to run the straps thru. You can, as I do, "X" them... left wheel to trailer right side, right wheel to trailer left side.
This way, the trike still has the rear suspension working... to bounce when you hit a bump. If you try to pull tight from the hitch or frame, a good bump can cause the suspension to lower (momentarily) and loosen your straps. Perhaps not a lot at once, but each little bit adds up.
Thanks Dennis!
Are you and Lenora planning on a return to Kerrville this October? Hope so...
Second that, I also do the front wheel that way when it is in the wheel chock, lets the suspension work, a lot easier in straps.
Hardleydoing
