Just got this trike and would like help with the lifting points. It has the water boards on the sides. Have a long lift with front extension. 1600 pound capacity. Thanks for any help.
Anywhere under the motor but behind the oil filter as @geol points out is fine. It wouldn't hurt to use a small block of wood between the motor and the jack. Honestly I don't do that but it's not a bad idea. Just make sure it's evened out.
Also in the rear, anywhere under the plate that the rear differential is mounted to is fine. You just don't want to try lifting using the arms to the right or left of the rear differential.
Thanks I hadnāt thought of looking there. Just trying to get a idea of what needs to be done since I have no service history.The CSC recommended jack point is on the centerline underneath the trunk.
If you visit the CSC website you'll be able to download the manual for your kit. https://img1.wsimg.com/blobby/go/196ab735-e9c7-46e6-bb49-a914633cbdf3/downloads/CSC Trike Owners Manual - 2017.pdf?ver=1751382122362 There's a diagram on the last page of the manual.
Enjoy your new toy.
Thanks to all who answered the post. It will help. Have decided to take trike to Litchfield il. Honda dealer for golden service to get everything checked and get a baseline to start a list of services. Iām kind of a stickler on knowing that everything is up to date. Hopefully the fuel gauge problem is minor. Thanks again.
