Are there any updates to the GL1800 brake (secondary master cylinder) recall??
We haven't heard from Honda since the first recall, and don't expect to. The dealer that did the inspection reported that the Champion kit we have de-links the brakes and the recall doesn't apply.
Why do some people report the dealer just checked the MC and the SMC and said they were OK, and some say the dealer replaced the front and then others say they replaced them both??
Then they were cheated... the recall states that they BOTH must be replaced and the system flushed... no exceptions. It does not say... Check it... Look at it... Replace it if... IT SAYS REPLACE IT!!!
Appears that some dealers maybe using the bike Vin # to get paid by Honda for work they haven't done...I saw this happen many times when I worked as a mechanic for a Ford dealership back in the mid 60's...
It does not say...
Check it...
Look at it...
Replace it if...
http://powersports.honda.com/recalls.aspx
VIN:
- YEAR: 2005
- CATEGORY: MOTORCYCLES
- SUB-CATEGORY: TOURING
- MODEL: GOLD WING
- NUMBER OF POTENTIAL RECALLS: 1
- LAST UPDATED: MAR 21, 2016
NHTSA RECALL NUMBER: 15V-700
CAMPAIGN DESCRIPTION: GL18 RR BRAKE DRAG RECALL
MFR CAMPAIGN ID: JV6
RECALL DATE: 10/16/2015
RECALL STATUS: VIN/HIN Required
SUMMARY:
AMERICAN HONDA MOTOR CO., INC. (HONDA) IS RECALLING CERTAIN MODEL YEAR 2001-2015 HONDA GL1800 MOTORCYCLES. THERE IS A POSSIBILITY THE SECONDARY MASTER CYLINDER MAY CAUSE THE REAR BRAKE TO DRAG.
SAFETY RISK:
UNEXPECTED BRAKING INCREASES THE RISK OF A CRASH AND RIDING THE MOTORCYCLE WITH THE REAR BRAKE DRAGGING MAY GENERATE ENOUGH HEAT TO CAUSE THE REAR BRAKE TO CATCH FIRE.
REMEDY:
HONDA WILL NOTIFY OWNERS, AND DEALERS WILL REPLACE YOUR MOTORCYCLE'S SECONDARY MASTER CYLINDER AND REAR BRAKE MASTER CYLINDER AT NO COST TO YOU. OWNERS MAY CONTACT HONDA MOTORCYCLE CUSTOMER SERVICE AT AT 1-866-784-1870. HONDA'S NUMBER FOR THIS RECALL IS JV6.
It does not say...
Check it...
Look at it...
Replace it if...
VIN:
- YEAR: 2005
- MODEL: GOLD WING
SUMMARY:
SAFETY RISK:
REMEDY:
Honda will notify owners, and dealers will replace the secondary brake master cylinder and the rear brake master cylinder, and flush the brake fluid, free of charge. |
Yep. Even though it's triked out and possibly disconnected, Mother Honda wants it REPLACED.
Mine is in the shop right now having it done with a complete system flush...front and rear.
