DK Custom PROJECT TRI-GLIDE Report w/ Lots of Pics
:laugh: Yeah, it's still a bit fatter than the FW. :)
It is hard to beat the usefulness and convenience of the Tour Pac. But I much prefer the low slung LOOK of the Trike with the Tour Pac removed and a rack in it's place.
Yeah, I told Devin I did not mind it being off of there for a month while we test fit different prototypes on the bottom of the TP....but after a few days, I realized how much easier it is to put stuff, and take stuff out of, the TP than the trunk. Sure looks better though.
I don't know if it's psychological or not, but it seems to feel a bit different too...can't put my finger on it...probably just in my mind. lol
Agree 100% - love the look!
Yep! :)
I kinda like the clean look of a bare back end,too.
Pictures don't do justice to that fat, clean back end on your Hannigan! :)
Today we thought we'd get the Power Duals installed and move onto a couple of other things.
Well....it did not work out that way. We got the PD's installed, less the shields, and fought an exhaust leak for over an hour.
We ONLY use tapered SE style exhaust gaskets when installing exhausts. But the PD's came with some gaskets (non-tapered), so we figured they knew best what would work with their exhaust and used them. No matter what we did, we could not get rid of the leak.
Off everything came, and we put the tapered gaskets in, no leaks. So we did it twice, but ran out of time before getting the heat shields installed.
I'm pretty stoked about getting these installed. As I mentioned before, I really like the look, & even though we have not run it outside, it sure sounds like a deeper tone too.
Here are a few pics...still dirty, but will be cleaning it up soon. Got to have the rest of the bike match the new headers! :)
Slip-on's off-
Headers off-
Power Dual package of parts-
Everything installed, less the heat shields & foot board!
We had a bit of time this afternoon and got a couple of things done.
1. We got the heat shields installed on the V&H Power Duals. Tomorrow, or this weekend, I'll get some seat time in. See how it sounds and if there is any perceptible change in power.
I like the look!
2. We've had a few people ask about installing the Stealth LED Driving Light on their Freewheelers, with no engine guard.
I had mine mounted off the engine guard with hinge clamps...but their request got me to thinking. It would be even MORE Stealth (and less expensive) if it was mounted with an L bracket down a bit lower.
We found the perfect spot. Right off the floorboard mount. There is plenty of room for adjustment to get the beam just right for lighting up the road.
Tomorrow, or Saturday, I have a few more things to do while it is still on the lift. Then I'll be taking it out for some more test runs, and at the same time will get the Stealth LED Driving Lights adjusted for maximum benefit. Will grab a few pics, day and night, to show what it looks like in the new location.
I like that location for a Tri and will consider it. Have to wonder about rocks flying off the wheel, although I added a fender extension which may help.
Got a few more things done, including some riding!
Here are a couple of pics of the Power Duals outside.
I think the tone may be a little deeper with them than with the 2-1-2 on there previously, but if so, it is very small. My butt dyno could not tell any difference in power, it may have moved the torque curve to the right, just a smidgeon. MPG stayed the same.
A mechanical dyno may show a bit of difference, but it was not enough for me to notice any significant difference in daily riding.
The Power Duals are a significant improvement over the stock headers, but I was moving from a performance 2-1-2 header to another performance 2-1-2 header.
So, for me, the change came down to looks. If I was moving from stock to the Power Duals, the benefit is looks, increased performance, and deeper tone.
I moved the Stealth LED DL's from the engine guard down to the floorboard mount. I think I like them here better...just a more stealth look. I will be putting on a front fender mud flap to keep any rocks from kicking up and hitting the lights.
Here is a pic at dusk-
A close up of it mounted-
At full dark.
Besides lighting up the road, it really improves the chance of folks seeing me, without blinding them.
To give an idea of how they light up the road...these two pics are looking straight ahead with the handlebars turned all the way to the left...
First is Without the Driving lights on-
Next is WITH the Driving Lights on-
Everything is more lit up and much crisper.
Here is something we have been working on.
This is the best we have gotten it so far.
I want the vent to glow, and after 5 different tries, I have it glowing pretty good with running lights and turn signals.
Here's a little video showing the signals flashing, click HERE
I think we can get it a little brighter without feeding back to the rider thru the other side of the vent. We'll see.
Hi Kevin,
I just received the Stealth LED Driving Lights and ChromeP-Clamps (real nice kit). Now I’m not sure if I want to use the P-Clamps for mounting to the engine guard or your new location justahead of the front footboard mount.
For the Footboard mount, did you fab a new mounting bracket (real difficult to see in photo)? And for the electrical, did you tie into thehead light circuit? Thanks in advance DJ
Hi Kevin,
I am currently betwixt and between on what to do.
Devin pointed out that the driving lights are a focused beam. Having them on the engine guard gives a bit more light to the sides. So that is a definite benefit of them being on the engine guards.
Having them mounted down low is a more stealth install, which I like. It is also one where it is a good idea to add a front fender mudflap.
At this point I am not sure which I am going to end up doing.
That said, we have L brackets, they are heavy duty (you don't want any vibration in your lights, that can be irritating). The L brackets are pretty much hidden when installed, but they are the same L brackets we make for our Streamliner Bullet turn signals, and you can see them in this pic-
If you decide you want to use the L Brackets, give the shop a call or an email and let them know. They'll fix you up.
On the wiring we tied into the Auxillary passing lamps, so when those go on the LED Driving lights go on.
Tying into your headlight would work also. The reasons I did not do that are-
I want them to be on whether on high or low beam.
If I tied it into both high and low beam then I would not have the ability to turn them off...say at a rally or in close quarters (parking, etc.).
Did you notice any light vibration using either the L-Bracket mount or engine guard mount during your test ride? This would easily help make my decision as for location.
It make sense to wire into the passing lamps. Thanks DJ
I'm looking at mounting those on the freewheeler and want them on all the time, low beams or high. Doable?*
Yes, it is easy to tie the wires into both the low and high beam, so whenever your headlight is on, the Driving Lights are on.
No, there is no vibration on either. That is why we use the heavy duty L bracket, so there will be no vibration. The hinged P-Clamps are also very solid, no vibration. If just comes down to which location you like better.
The engine guard mount gives a bit wider light spread, possibly more useful on country roads with lots of critters. The floorboard mount is (to some) a more desirable aesthetic, being a very stealth mount.
haha, like I mentioned, I'm not sure which one I'm going to end up settling on for myself. :)
So we did a bit more work today on the Tri-Glide.
First thing was we mocked up (just taped, and not even straight or centered) a vent to the fender well. I have been thinking about doing this for years.
There is a fair amount of air that hits this relatively flat spot, it can be quite warm, and some it flows up the side of the passenger.
I'm thinking with a vent there it may do a little to speed up the flow of air past the engine, and also reduce the amount of air that flows up the passengers side.
Here's my BIG QUESTION-
Has anybody cut into the plastic body? I am concerned, that even with taping off, and careful cutting and drilling, it may chip the paint/clear.
Any experience/advice in cutting into the body would be greatly appreciated.
We broke down the TG a bit, I went to work on installing a newer prototype of the oil filter relocation, while Devin worked on installing some rear fender LED's.
The OF relo bracket we've been running has held up well to over 1500 miles of riding. But it did not leave clearance for the passenger floorboard to be on the lowest adjustment, AND for the adjustable passenger pegs.
So we cut a new one, with a bit different configuration, so that everything would fit nicely.
While I was doing that, Devin was installing the second prototype of our rear fender LED's.
btw, we are NOT holding up the rear of the TG with the jack stands you see. There is a flat scissor jack under the crossbars below the trunk, and then jackstands on either side providing some stability.
Here's a pic of the, "hidden while off", fender LED's. They are run-brake-turn, and are mounted to a special bracket we fabbed...not just for mounting how/where we wanted the LED's, but also to protect them from water/debris coming off the rear tires. That's the theory...we'll see how it holds up to rain, mud, gravel, etc. :)
We're still in the beginning stages...lot's more to come, but probably not much til after the first of the year.
I decided to install the Stealth LED Lights on the engine guard. After everything is installed final beam alignment will on hold for the weatherman's cooperation. :)
The prototype adding a vent to the fender well is interesting but more interesting how to keeping water, dust, dirt off Mary. ;) Your idea of moving more heat away from the passenger gives my wife hi-five's .
Also, I like the prototype of your rear fender LED's. I installed rear mud flaps and not sure if these would interfere or help. But you have my interest.
And thanks for all your feedback. DJ
Cool!
Yeah, moving the air along is what we've been talking about for years...we should know soon if it works. ThumbUp
Yesterday, while doing the rear fender LED's, I was talking to Devin about how I might want to put rear mud flaps on...and we have some ideas of how to incorporate them into them. We'll see how it works.
I sure like all this light stuff, I know what I will be doing to the trike. I got in on Ride Time Technology lights as there were developing stuff for the tour pack. It sure lit up the rear of the ultra classic when the signal lights were on. I am in Dallas at the present, but when I return I will get to changing some stuff on the trike. Jim
Cool!
I've never been into lights much, most I ever did was install some halogen driving lights.
But after riding with my first LED headlight a few years ago...it is so much better! That, plus the growing number of inattentive drivers on the road, I am really enjoying lighting things up with LED's. :D
Today we spent another 5 hours on the Tri-Glide and don't have a single picture to show for it.
We sat looking at it a good deal of the time. ( I suppose I could have asked Mary to take a pic of us sitting on our stools staring at it and scratching out ideas on yellow pads..but did not think of that til just now. :laugh: )
We did do some measuring for a new idea we came up with.
Many folks run fork fangs and/or lower tree baffles. These are fine to run during cold weather, but they block so much wind to the engine, that at 70* or more they really have a negative impact on the engine temps.
Sooo...one of the things we sat down to do today was to figure out if there was a way to reduce wind to the rider WITHOUT reducing air across the engine, and preferably, increase the amount of air across the engine.
We think we came up with an idea. We measured, made some cardboard templates, & measured some more. Now it is just a matter of cutting them out of metal, bending them, and testing them out!
In the meantime, I am hoping to get some feedback from those who are running fork fangs and/or tree baffles.
Do you run them:
1. To reduce cold air from hitting you
2. To reduce hot air from hitting you
3. To reduce buffeting
4.
Other
I would really appreciate any and all input. :)
Other than the above, we reviewed what we have done, and what items are in the works (14 mods are either done or in process), and looked at what else we want to do.
I just counted them up, and we have 27 more ideas that all sound pretty good to us right now. It's going to be a busy winter, and early spring to get all those done! ThumbUp
Oh, I do have one picture. Seems sometime in the last month, my front fender developed a crack in the paint. Right down the center.
There is nothing that has hit it, from the top or the underside. It appears to be a flaw in the paint/clear-coat that just took some time to show up. I need to get it to the dealer so they can see it and order a warranty replacement.
Happy New Year!
It will be 2016 before we do anymore work on it. Although, we will be going for a ride on New Years Day!
Kevin, I installed a tree baffle to try to block some f the air that comes from under the fairing. Not convinced how much it helps.
Tree baffle/ Fangs
It's difficult to figure out air travel when redirected unless a good fan and smoke wand is used. Just like used in arodynamics. The fan is the easy part, never investigated as to purchasing a smoke wand. I was also told they do not affect the air to the motor, only redirecting the upward air down and out. However I like the wind tunnel idea and wish I had the time and place to play with the idea.
DK project trike
What kind of air cleaner are you using? I see two stainless braided hoses coming out of the air cleaner. What are they for and where do they end up at and what is attached to the end of them?
Thanks for you response in advance
Dk project trike
You mentioned a few lines on a oil filter relocation. Could you tell me a bit about it. My Email is martingw@telus.net If you E mail me I am also the one that had the question about the air cleaner. If you prefer not to E mail you can just answer on the forum
Do you run them:
4. Other
Kevin,
I've had them on my 2013 trike for about 2 1/2 years now and have them on year round. They do an incredible job of blocking the wind that comes up and over the lowers. The reduction of buffeting is pretty dramatic and is especially appreciated on long days of riding.
As for making the engine run hot, I can't really say. You helped me out a lot to increase my mileage and try to get the engine to run cooler. Improved gas mileage - definitely worked out, thanks! Reduced engine temps - not so much. Still get up close to 300 degrees even in cold weather. Makes me think there's something else going on.
I'll definitely be interested in seeing what you guys come up with. Always thought one with slits in the fin that angled the air down towards the engine more would be an interesting idea. Keeps the air flow headed on the engine while still stopping the buffeting to the rider. Not sure if these are necessary on the 2014 and newer trikes though with the fairing vent system. From what I've heard that helps a lot.
handle bars and sheep cover
Just wondering what Mr. DK is using for "Handle Bars" (size & Name) and where he got his Sheep cover from.?
AAAAAAAAWWWWW Kevin, the dealer will tell you it will buff right out.
Yeah, they might :laugh::laugh::laugh: ...til they touch it and feel the ridge.
Hopefully this weekend I will be able to test our idea. We have quite a bit of data already from over 20 test runs, so it should be easy to compare to see if it is better, worse or insignificant.
Yeah, the fan is the easy part. I've had some big fans in the past when we had our hay farm. I think a smoke wand should not be that big of a challenge. But I was thinking we'd need a big tube/tunnel...that is where it could get expensive.
The air cleaner is the Outlaw HiFlow 587 with a Chrome Bobber Cover and the Premium Discrete Breather. It also has the Stainless Braided Hose and Chrome Hose clamp covers.
The purpose of an External Breather System (EBS) is for performance, engine longevity, and tune stability. You can see the full details on the benefits of an EBS at this LINK
On my EBS it ends up between the frame and the left rider floorboard, and has a filter on the end of it. However, it can be routed where ever you like.
You can see the air cleaner HERE
You can see the braided hose and hose clamp covers down toward the bottom of this LINK
On the oil filter relocation, we now have over 2000 miles of testing on it and are very happy with it's functionality. It makes changing the oil super easy and no mess. It also lowers the oil temps by about 10*. This is because the filter and the hose are out in the wind, and also because the filter is no longer blocking wind to the front of the engine.
We are still working on the aesthetics, and tweaking a few things so that the passenger floorboard retains as much flexibility for add-ons as possible.
We are shooting for a Feb. release date. Price is still not determined...brass fittings are expensive and we are still negotiating on them and some other parts.
If you have any other questions about it, feel free to post here, or to email me at Kevin@DKCustomProducts.com
Do you run them:
4. Other
Kevin,
Thank you for the input on why you run deflectors. Is it head buffeting that you are mostly concerned about? OR ???
Yes, the fairing vent definitely helps on head buffeting for me on the 14.
Yeah, I agree, 300 is too hot for ET reading off a Power Vision, even on a hot day. It was 39* when I left for the shop today. I took the long way, so it was fully warmed up by the time I got there. Ambient air temp was 42* and ET off the PV was 196* when I arrived.
Pretty sure he made his own bars.
Yes, I made my own, using the stock bars, extended 9" longer by welding a 9" straight section of pipe on each side in the already straight section of the stock bars.
Here's a pic of the bars after welding the 9" section into them...but before I got them powder coated.
Much more comfortable, and I have the following mounted on them with room to spare.
Drink holder
Power Vision
Cig Lighter
Video Camera mount
The sheepskin was purchased for the 2011 from these folks-
http://www.sickafus.com/shearling/sheepskin-hides-rugs.html
The one on the 14 was on the 11 before. We've put over 70,000 miles on it. :)
project
do you think the new filter relocation will have any effect on the Harley warranty or the extended warranty
roadscholar331
