2019 trike tuner?
El Lobo
30+ Posts
Aug 13, 2019
37
40
Alcalde, NM
Benicio
Hello fellow Trikers
I want to install a tuner on my 2019 Tri Glide. Is anyone using the Screamin Eagle Smart tune PRO. auto tuning? Any feed back is greatly appreciated .
Thank you all.
El Lobo
I just put my PV on the 20, stock improved tune, definite improvement, no other changes yet, lol. One thing to remember, anything Harley/screaming eagle has to comply with epa regs, so an aftermarket tuner will out perform the Harley tuner. I believe the pro tuner has wide band sensors, so you have to drill and tap your existing sensor holes, should be provided with the kit, I think, but if you go back to narrow band sensors they have an adapter, kit, and whether or not the stock sensors will stick out into the exhaust flow enough is the question. Do some reading and research. If warranty is an issue, hd/se is the only tuner available.
Have one on my 2020 TG. Can’t compare it to any other but the tuner with all SE upgrades (air, pipes, cam) runs great. Be Safe BK
TheTiler
