You will not damage the system
Are you asking me to start over?Can we start over?
Does CarPlay only work with the headset plugged-in?
Yes sir - that is it.![]()
Harley Davidson compatible Apple CarPlay adapter with headset connector — Logsdon Audio
Harley Davidson compatible Apple CarPlay adapter with headset connectorlogsdonaudio.com
Not you! JamjrAre you asking me to start over?
If so, Carplay can work even if a headset is not plugged it. You can do three things.
1. Install the WHIM (I do not recommend now), Now you will need a wireless headset.
2. Put in the Car play jumper under the fairing
3. Install the Logsdon plug in the headset plug.
Pete - what are you riding. A 2023 TriGlide? Are you using AA or carplay?Been following this interesting thread……being an ‘ole Fart I’ m not very up to date on all these new lectric gagets, so I sent for the plug in adapter and see what happens…..I’ll respond when I receive it (2023 Ann. TRI).
EVERYONE RIDE SAFE!
Pete
Using wired headsets?
Great - then, all you need to add is the logsdon plug. Remember, it goes in the passenger plug.Riding stock 2023 Anniversary TRI Glide….. I just want carplay no headset.
Cycle7447 Why does it make a difference if you have to put it in passengers plug and not driver? ThanksGreat - then, all you need to add is the logsdon plug. Remember, it goes in the passenger plug.
All of the reports I have read - and even trying it in the rider's plug, for some reason, it does not work.Cycle7447 Why does it make a difference if you have to put it in passengers plug and not driver? Thanks
Also, if you read the instructions, it says put it in the passenger plug.
Features:
* Plug-n-Play, no taking apart your bike to install parts
*Allows you to remove and connect headsets if desired with no modifications
* Easy installation (plug into the passenger headphone port, and plug your phone into the USB connector)
* You only need one of these to activate Apple CarPlay
This item ONLY works on 2019 and up Harley Davidsons with the BOOM GTS radio!
This item will NOT work if you have a WHIM installed or have had your radio flashed for a WHIM. You would need to have your radio reflashed for it to work.
This item will NOT work on CVO models.
Part # 7PCPEB
I never did update my experience using CarPlay after you guys got me up and running. I used it for the 2-day run up to the NC mountains to meet the boys.Hey, glad to hear it worked out and all is running well.
Running wireless is not that costly. My AA wireless is about $45 - look for any coupons when buying them . Ottocast had a $30 coupon on Amazon.
Good luck
Ok, having some time to play around with the CarPlay. With the jumper plugged in under the hood and hooking the 2 wired headsets in. I can talk to the rear headset and she can hear me fine but when she talks nothing comes through. (Hear radio fine though headset). Take jumper off and plugged headsets back in and all is fine with headsets but no CarPlay.(Wirelessly or plugged into the usb). So for now just leaving the jumper plugged in and let her talk to me in my ear until I figure this out.You will not damage the system
I tried that with and without wireless CarPlay adapter.The jumper "fools" the radio that a headset is plugged into the system and mess with the headsets.
With no jumper and headset or sets plugged in and phone plugged in to USB Carplay should work along with the headsets.
You may have to "forget" Carplay in your phone and reenter Carplay.
Do you have a WHIM?
No just have the corded headsetsYou may have to "forget" Carplay in your phone and reenter Carplay.
Do you have a WHIM?
As was suggested before just get the jumper for the passenger headset plug so Carplay will work without any headset plugged in when you don't use them.No just bought the corded headsets for the bike. Not going to used them that much.
But I want CarPlay with the headsets and it won’t let me.As was suggested before just get the jumper for the passenger headset plug so Carplay will work without any headset plugged in when you don't use them.
If you want to send me your phone number I can try to help you.But I want CarPlay with the headsets and it won’t let me.
SentIf you want to send me your phone number I can try to help you.
(redacted)@aol.com
Al good! It was good to talk to someone then sit here and type.Yall do know you can instant message one another don't you?
I meant as in you can instant message one another to share your email or phone number and such, rather than post it in the thread, in case you dont want to share that info with the world.Al good! It was good to talk to someone then sit here and type.
I discovered the exact same problem after I installed the CarPlay jumper. The passenger intercom can’t transmit through the mic. But the rest of the headset works fine. Were you able to figure out how to get around this problem with the jumper?Ok, having some time to play around with the CarPlay. With the jumper plugged in under the hood and hooking the 2 wired headsets in. I can talk to the rear headset and she can hear me fine but when she talks nothing comes through. (Hear radio fine though headset). Take jumper off and plugged headsets back in and all is fine with headsets but no CarPlay.(Wirelessly or plugged into the usb). So for now just leaving the jumper plugged in and let her talk to me in my ear until I figure this out.
