2014 Tri Glide rear brakes, HELP !!
Welcome to Trike talk and your first post
The first thing to do is put some slack in the E brake
Next step, remove rear master cover on reservoir, remove some fluid ( as you push the rear pistons in the fluid in the reservoir will rise Next, slowly ( using a C clamp ) push the piston in until it seats ( be careful to not push any further)
Now you can install the pads and reassemble caliper( I like to bleed each wheel as I go along)
Do the same for the other caliper
Once you are done, slowly pump the pistons out and rebleed the system
The last step is to readjust the parking brake
Rear brakes 2014 Tri Glide
Jack, thanks for your reply on my question, we have Ebrake fully disengaged, but piston will NOT move, no matter how hard we compress C clamp. I know on older models (only ones I could find on "YouTube" , you had to remove a bracket from the Ebrake.......your saying the piston should just slide back into the cylinder pretty much the same as a cars front brakes?
Yes, surprising, the pistons do not move much, try opening the bleeder valve a touch, this will force the fluid out as the piston compresses
Your brake caliper and pads should look like this
