Stallion dash and signals not working
andrew welcome possibly the panel micro processor went bad. my wifes just did same thing except the turn signals work. i have a used panel off ebay coming to see if thats my issue.
I have a 2013 Thoroughbred Motorsports Stallion.
The other day, my signals and dash light stopped working.
I’ve checked fuses and connections to no avail.
Does anyone have any advice?
Maybe you have a defective flasher unit??? It is located around the oil dipstick area. If you hear it clicking, look for it in that area.
Andrew sorry for so late getting back to you. That circuit is powered off the F1 5amp fuse. It would normally go to the dimmer panel but the Stallion does not have that panel at least on my "08" The circuit goes to the instrument panel via a Blue/White wire. I expect you have either a bad fuse or a poor connection at the back of the panel. Removing the instrument panel is not hard just time consuming. Check for power at both sides of the fuse and if that is good then the connector for the blue/white wire at the back of the panel. That's the whole circuit according to the wiring diagram I use from an "07" Ranger.
Let me know how it goes. The should be checked with the key in the on position. Also let me know if you cannot find the fuse.
My 2013 did the sane thing .Looked around outside lights working! Haven't had time to check possibly block connector under hood
Good morning
Ted did you get your cluster fixed. Did it show signs of going bad over time
or did it just quit. another question is does this have the led's installed for dash lights:confused:
Dragon
Good morning
Dragon
bought a used cluster for a 07 ranger on ebay works just fine. no hint just quit. non led i put led bulbs in the original but did not like them. they worked good in the turn signal slots though.
Trustme54
