Stallion dash lights
May 31, 2011
31
Mobile, Alabama
My dash lights (not warning lights) only come on if I turn on my heat or AC. Is this normal because my trike was in an accident before I purchased it and there is nothing about this in the owner's manual
okay answered in other postig, but now you say they only come on then? If you turn the full headlights on the dash lights do not come on? THis is NOT correct. Dash lights wired wrong.
No you should not have any lights come on when you turn the AC/ Heat on. Sound like you have a loose or cut wire making contact with the light wiring harness. If you look under the pannel where the light switches and AC/Heat switch are, you can see how that might happen. Best way is to trace the wire for your dash lights back to the light switch and see if there are any cuts or breaks in that wire.
I had a similar problem and was told by TMS to check rear ground. It is located on chassis near the right rear tire. Follow wire from A/C blower to find it. it solved my problems.
Trustme54
