2009 Thoroughbred Stallion pedal adjustments
Sep 25, 2024
6
2
Idaho
Ron
Does anyone know how the gas and brake pedal adjustment work? Loosened the two bolts but was unable to turn the long-threaded rod.
Rocker switch on the left side below the voltage and air bag led readouts. One rocker is for the air bags and the other one is for the screw drives for the pedals. They may be stuck if you ran them too far and jammed them up. Lube the screw drives and hope they loosen up. Rick
dhinzman1
