Handle bar length
Thinking of putting new handle bars on my 2017 triglide couple of questions.
longest length I can put on without extending cables and wires?
any suggestions on bars that work good?(I'm 5 10)
THANKS
I believe 10"possible 12" apes depending on width Harley makes pull backs but I don't know if they are higher. Khrome werks I think 12" 2+2 Narrow Sweepers from Khrome werks some people have switch to them, I could be wrong I did the 2+2 Wide Sweepers they are close to 12" and needed to change Clutch cable on my 09' they are 4" wider. Good luck on your search bars are a very personal thing what fits one doesn't the next. Travel safe Fred
View attachment 87860View attachment 87859
The factory bars on my Freewheeler are 12" & I really like them.
Suggest KromeWerks 2+2 Narrow sweepers. They work well for me and I am also 5' 10" .
The 2" higher and 2" pull back sure makes a difference on a long day's ride for sure. :good: My smashed right wrist needed a little straighter grip the Wide one's gave me. Fred
I just installed the 2+2 narrow sweepers on mine and really like them. Mine is a 2011 all I had to change was clutch cable.:clapping:
12" rise is the maximum you can go without having to change the front brake and the clutch hydraulic lines. You will need to add the short extension jumper for the handle bar switch cables but the existing throttle by wire cable will be long enough as is.
Ron A
