2014 HarleyTrike Radio
Feb 17, 2020
5
1
PALM BAY
After starting the touch screen radio on my 2014 Harley Trike beeps 3 times, pauses, beeps 3 times, repeatedly. Someone said this indicates the radio is defective & requires replacement. Any ideas?
Welcome to Trike Talk, have you run a diagnostic scan yet?
You can check your trouble codes on this list here https://www.triketalk.com/forum/thr...s-bcm-codes?highlight=harley+radio+diagnostic
Here is how you put your bike in diagnostic mode
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold. For 2014 & newer touring models this will be the toggle switch on the left control mount.
3- Turn ignition switch to Ignition and release the odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM(Electronic Control Module)[EFI] /Ignition Control Module[Carbureted])
S = TSM/TSSM (Turn Signal/ Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
Jim, Welcome to Trike Talk 👍👍..Hopefully someone will chime in with the answers to fix the problem ......Again Welcome 👍..
  • :welcome: To the Trike Talk Family! FROM SOUTH
    attachment.php
    Angleton, TX
    Howdy Jim!
    :wave4:​
If you have the extended warranty, you don't have a problem.
I had a radio/CD unit problem a few years ago - my EXP paid for a new one. :D
last year my radio went blank and would not come back on until I shut the bike off and it seems like it would reset and work until I cranked the engine. I finally figured out my battery was going back when it would not crank at all. once I replaced the battery I have had no more problems, it did not make sense why it would not work after the engine cranked but after the new battery no problems.
mtorcyclejoe
